Home > Maintenance & Mods (L322) > Turbo change |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Trust me, you don't want to do the N.S. one... |
23rd Apr 2014 8:44pm |
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 |
Do you have to do them as a pair or is one at a time ok? Bushy
23rd Apr 2014 9:01pm |
Its good practice to do a pair... But i have heard of Main Agents doing just one... |
23rd Apr 2014 9:15pm |
That's what I thought. Bushy
23rd Apr 2014 9:37pm |
Good luck with the rest of yours sir |
23rd Apr 2014 9:51pm |
Sorry for the delay, I've been away.
28th Apr 2014 4:28pm |
Make sure all of the induction side is connected properly and tightly. Get a good check of all the pipes for splits as with the pressure going through them if there is any sort of hole or split it will whistle really loud. Humans whistle at around 1bar of pressure. Your car has probably 3-4 bar under load.
29th Apr 2014 10:40am |
RoryM Member Since: 02 Mar 2013 Location: Ireland Posts: 51 |
how would you know if it was the MAF sensor? what would be the symptoms? I maybe imagining it but it feels like its taking a bit longer for the turbo to spool up and that its slightly down on power. again, this could all be in my head though.
29th Apr 2014 11:09am |
Normally a rough engine with/without struggling under load, troubled starting sometimes. But there can be lots of possibilities. If you download the rave for our car, you'll see in there it suggests around 5 symptoms that could all be happening or just one.
29th Apr 2014 1:05pm |
