![]() | Home > Technical (L322) > Automatic gear box oil level |
Wookie Member Since: 26 Mar 2014 Location: Bournemouth Posts: 14 ![]() ![]() ![]() |
Can I check gearbox oil level? |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
Sure! Go ahead! 2006 4.2 SC
^ what he means is someone in the car with their foot on the brake and hand brake on with the engine idling, the car in Drive and you lying underneath the car undoing the fill/level plug on the gearbox.
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
+1 |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
And the gearbox oil temperature needs to be 40(ish)deg c... |
Interesting why does the car need to be in drive? (I like learning) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35631 ![]() ![]() |
i believe it pressures the system.... ... - .- -.
When in Neutral or Park ,there will be more oil in the box as various clutches, pumps etc will not be using it. Therefore, if you check the level when in this state, there will not be enough fluid once you start operating the box.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
Jeepers guys, please don�t recommend something potentially dangerous like working underneath a vehicle with the engine running and Drive selected! The engine must be running to ensure that the torque converter is full together with the cooler and its pipework. Also the valve block needs to be full (they contain a surprising amount of fluid - you can see all the worm-tracks in the photo below).
To ensure that all the valve block galleries are full you start in Park and then select Reverse, Neutral and Drive holding in each position for 3 seconds before returning to Park again. Then check the fluid level. The level must be set with Park selected, not Drive. Phil Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
silversurfer Member Since: 24 Oct 2013 Location: londinium Posts: 84 ![]() ![]() ![]() |
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 ![]() ![]() ![]() |
Sorry to go slightly off the beaten path here but if you were flushing the box using the 3 oil change system. At which change would you do the filter? Is there any other way to flush out all the old fluid? |
Thanks for clarifying the correct method Phil |
I used the RRPhil method since I had no one to help and it worked |
