Home > Technical (L322) > Automatic gear box oil level
Wookie
United Kingdom 2006 Range Rover SE TDV8 Giverny Green
Can I check gearbox oil level?
Post #255176 19th Apr 2014 8:28pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Sure! Go ahead! 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #255184 19th Apr 2014 9:26pm
Re: Automatic gear box oil level
Only with the car running in Drive for a short period... Remove the filler bung in the Gearbox and see if it starts running out! If not, you need to add some sir Thumbs Up
Post #255209 20th Apr 2014 12:25am
^ what he means is someone in the car with their foot on the brake and hand brake on with the engine idling, the car in Drive and you lying underneath the car undoing the fill/level plug on the gearbox.
The person in the car should be someone you trust implicitly. Thumbs Up Smile
Post #255220 20th Apr 2014 6:55am
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
+1 Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #255223 20th Apr 2014 7:39am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
And the gearbox oil temperature needs to be 40(ish)deg c...
Post #255234 20th Apr 2014 8:29am
Interesting why does the car need to be in drive? (I like learning) Smile
Post #255242 20th Apr 2014 10:17am
i believe it pressures the system.... ... - .- -.
Post #255249 20th Apr 2014 10:29am
Full Fat Ray
When in Neutral or Park ,there will be more oil in the box as various clutches, pumps etc will not be using it. Therefore, if you check the level when in this state, there will not be enough fluid once you start operating the box.
Post #255251 20th Apr 2014 10:34am
Post #255253 20th Apr 2014 10:38am
RRPhil
Jeepers guys, please don’t recommend something potentially dangerous like working underneath a vehicle with the engine running and Drive selected! The engine must be running to ensure that the torque converter is full together with the cooler and its pipework. Also the valve block needs to be full (they contain a surprising amount of fluid - you can see all the worm-tracks in the photo below).
To ensure that all the valve block galleries are full you start in Park and then select Reverse, Neutral and Drive holding in each position for 3 seconds before returning to Park again. Then check the fluid level. The level must be set with Park selected, not Drive.
Phil
Post #255261 20th Apr 2014 11:47am
silversurfer
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Orkney Grey
Thumbs Up As above and also put back in exactly the measured quantity that came out when I replaced the sump with integrated filter. I was also surprised that several bolts were corroded, but managed to get them out without them sheering .
Post #255324 20th Apr 2014 7:57pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
Sorry to go slightly off the beaten path here but if you were flushing the box using the 3 oil change system. At which change would you do the filter? Is there any other way to flush out all the old fluid?
Post #255332 20th Apr 2014 8:43pm
Thanks for clarifying the correct method Phil Thumbs Up
Post #255334 20th Apr 2014 8:47pm
ebajema
I used the RRPhil method since I had no one to help and it worked Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #255337 20th Apr 2014 9:00pm
