Home > In Car Electronics (L322) > '02 HSE ICE Car PC Project (Carx to XBMC to FFRR-PC!)
Page 6 of 6 <123456
stormindes
United Kingdom 2003 Range Rover Vogue Td6 Oslo Blue
Thumbs Up Thanks @Joe90, its now on my 'to buy, then do' list along with many other things.
Right now more urgently is to find out which bright spark of a contractor decided that my car would look so much better with a coating of fresh concrete dust straight from the back of stone saw!
Big Cry How I just love spending hours waxing the paint to a mirror finish, words fail me Big Cry
Post #218830 26th Oct 2013 9:21am
Smegordead
United Kingdom 2002 Range Rover Vogue Td6 Buckingham Blue
Joe90 - I'm new to the forum so can't PM you but hoping you can help - I've read through your previous post and I know I should be able to work this out but I have a '02 Vogue and I'm trying to get video through the OEM headunit. I can see your picture for the pin out but struggling to understand what and how I need to connect to get a picture.
Hope you can help
Luke
Post #254843 17th Apr 2014 10:32am
Simplest way to approach this is to "think" you are just installing a reversing camera.
Composite Video Pos & Neg go to Pins 13 & 14 on the WHITE connector
The video will only show up if you "tell" the car you are "in reverse". This is done by grounding pin 17 on the BLUE connector.
More details of what you are hoping to achieve, what equipment you have etc. will help me and others help you Thumbs Up .
Post #254849 17th Apr 2014 11:21am
Smegordead
That's genius - thank you for getting back so quickly.
So to be clear if I strip a single phono cable I know I'll have two cables inside - which is which or does it not matter?
Is there a way of getting stereo sound into the main sound system too? I was thinking of plugging in an Xbox.
Thanks again, it's so good having you guys around Smile
Post #254852 17th Apr 2014 12:31pm
It does matter. If you strip a phono lead the "pos" should be sheathed, the neg should be just wire around the outside. If in doubt check at the plug.
To get stereo, the best solution is to send off your BM54 unit (Radio) to Baris (on the forum) to get the Aux In fitted to the unit. This can either be sorted so you simply add pins into the BM54 or Baris can fit phonos in the unit.
The alternative is to follow my howto and splice into the tape unit wires. This means you have to select tape on the Bord Monitor to get sound before you activate the video feed (otherwise you can't see what you are doing!)
The video sound feed is only mono. .
Post #254865 17th Apr 2014 2:21pm
Page 6 of 6 <123456
