![]() | Home > In Car Electronics (L322) > '02 HSE ICE Car PC Project (Carx to XBMC to FFRR-PC!) |
stormindes Member Since: 20 Oct 2013 Location: United Kingdom Posts: 13 ![]() ![]() ![]() |
Smegordead Member Since: 26 Mar 2013 Location: Maidstone, Kent Posts: 27 ![]() ![]() ![]() |
Joe90 - I'm new to the forum so can't PM you but hoping you can help - I've read through your previous post and I know I should be able to work this out but I have a '02 Vogue and I'm trying to get video through the OEM headunit. I can see your picture for the pin out but struggling to understand what and how I need to connect to get a picture.
Simplest way to approach this is to "think" you are just installing a reversing camera.
That's genius - thank you for getting back so quickly.
It does matter. If you strip a phono lead the "pos" should be sheathed, the neg should be just wire around the outside. If in doubt check at the plug.
