Home > Technical (L322) > Remote Locking Receiver (photos / diagrams needed) |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
Anyone able to help?? There is a difference between knowing your sh!t and knowing you're sh!t
21st Apr 2014 2:28pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
Would this help?
21st Apr 2014 2:54pm |
thanks looks like #13 is the only part I could have interfered with now know where to check connections There is a difference between knowing your sh!t and knowing you're sh!t
21st Apr 2014 2:56pm |
Nothing obviously loose but disconnected and reconnected box and now I have 4 keys that lock and unlock. Just need to get the 2 new ones cut so I can use them to start the car as well There is a difference between knowing your sh!t and knowing you're sh!t
21st Apr 2014 4:21pm |
Possibly just a bit of minor corrosion on the connectors that disconnecting and reconnecting cleared. |
21st Apr 2014 4:35pm |
Only problem now is that the radio reception isn't showing the stations so I guess I have to take the rear apart again to check for anything loose radio aerial wise. There is a difference between knowing your sh!t and knowing you're sh!t
21st Apr 2014 8:16pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Try a hard battery reset sir... A lot less work then removing the rear panels again |
22nd Apr 2014 7:41am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
Could be cos you tried re coding the keys and hence have wiped the stations from the memory. Are you getting reception/can you tune it?
22nd Apr 2014 8:15am |
All sorted (hopefully) driving to work this morning tuned in manually and while in traffic played with autostore etc... and got station names back and all seemed to store OK. Now just have to see if the work when I next get in. Maybe just my short drive round the corner last night wasn't enough to et everything set up. There is a difference between knowing your sh!t and knowing you're sh!t
22nd Apr 2014 9:51am |
