Home > Technical (L322) > Folding Mirrors Mistery
ukrangie
Is it worth adding tips like this to a FAQ area?
Post #9635 18th Dec 2009 1:23am
Vogue Owner
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Java Black
Fixed
Finally got round to tinkering with the mirrors.
Pushed one back to the fully back position , pressed the button a couple of times and hey presto - all working and synced.
No need for the stealers on this one.
Cheers Guys! CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : L322 Range Rover
GONE : 2007 MITSUBISHI OUTLANDER
GONE : SAAB 9-3 VECTOR SPORT
GONE : BMW M3
GONE : SIERRA COSWORTH
GONE : LOTUS CORTINA
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #13160 14th Feb 2010 12:01pm
tucker_j
Top tip guys. I noticed my mirrors were out of sync but two presses of the button later they are working perfectly again
Post #18362 17th May 2010 12:19pm
mouse470
To reset out of sync mirrors try a battery disconnect and re-connnect press mirror button and hay presto promblem fixed(will have to reset clock and radio presets)
your welcome
Post #19436 4th Jun 2010 10:22pm
Chriscase200
England 2006 Range Rover Vogue SE Supercharged Java Black
Just had the same problem tonight. I noticed that it happened when I was just coming out of reverse when the passenger side mirror was tilting back up again. Don't know if this was the reason but it could be.
Tried the double click a few times and problem solved. I will wait for the mirror to go back to it's normal position first from now on before folding the mirrors. Range Rover Vogue 4.2 V8 Supercharged 2006MY
Post #25416 12th Aug 2010 10:01pm
RRV
United Kingdom 2015 Range Rover Vogue TDV6 Santorini Black
Just done the "double click" of the button and now mine too are synchronised once again!! Thumbs Up If you have nothing nice to say,say nothing at all.
Post #26712 29th Aug 2010 2:22pm
Mojo
2005 Range Rover Vogue Td6 Buckingham Blue
I have the same issue, so will try double clicking mine this eve, Thanks for the advice.
Post #36337 16th Nov 2010 4:52pm
Mojo
side mirrors malfunction
The technique worked for me thanks. both side mirrors working as expected!
Cheers
Post #40163 30th Nov 2010 11:31am
dan_uk_1984
Whilst fiddling with the mirrors it is worth bearing the following in mind:
If the “mirror fold” button is pressed more than 5 times within 1 minute, the mirrors will extend and the mirror fold-in feature is disabled for 3 minutes.
Post #40167 30th Nov 2010 12:25pm
dan_uk_1984
FYI - I've now added the info from this post and a few others to the WiKi:
http://www.fullfatrr.com/wiki/Folding_Mirrors
Post #40175 30th Nov 2010 1:39pm
