![]() | Home > Technical (L322) > Folding Mirrors Mistery |
ukrangie Member Since: 20 Jun 2009 Location: Kent Posts: 520 ![]() ![]() ![]() |
Is it worth adding tips like this to a FAQ area? |
Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234 ![]() ![]() ![]() |
Finally got round to tinkering with the mirrors.
mouse470 Member Since: 15 Jun 2008 Location: bracknell Posts: 2 ![]() |
To reset out of sync mirrors try a battery disconnect and re-connnect press mirror button and hay presto promblem fixed(will have to reset clock and radio presets)
Chriscase200 Member Since: 12 Aug 2010 Location: North West Posts: 9 ![]() ![]() ![]() |
Just had the same problem tonight. I noticed that it happened when I was just coming out of reverse when the passenger side mirror was tilting back up again. Don't know if this was the reason but it could be.
RRV Member Since: 05 Oct 2009 Location: Midlands Posts: 648 ![]() ![]() ![]() |
Just done the "double click" of the button and now mine too are synchronised once again!! |
Mojo Member Since: 08 Jan 2010 Location: UK Posts: 15 ![]() ![]() |
I have the same issue, so will try double clicking mine this eve, Thanks for the advice. |
The technique worked for me thanks. both side mirrors working as expected!
Whilst fiddling with the mirrors it is worth bearing the following in mind:
FYI - I've now added the info from this post and a few others to the WiKi:
