![]() | Home > My Range Rover > My �4,600 TD6 Project |
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 ![]() ![]() ![]() |
Excuse my ignorance Riverstick but is the fitting of the Torque convertor a big job? Am I right in assuming the car will have to be taken to a decent mechanic and the gearbox removed? Travelling around in circles again. |
Riverstick Member Since: 06 Mar 2014 Location: Cork Posts: 117 ![]() ![]() ![]() |
Hi Nicedayforit, I have wondered about this also...I think it probably does protect it for a while, but it becomes overwhelmed with the amount of debris entering the system and eventually cannot cope any more...the same way as a component in an engine breaking up will eventually contaminate the entire oil system of the engine irrespective of how good the oil filter is. Tony 2008 Range Rover TDV8 435,000kms 2015 Range Rover L405 SDV8 Autobiography 2008 Ford Focus1.6 tdci Titanium DPF deleted |
cial Yes...no harm to give it to a guy who knows what he's at. you shouldn't have too much trouble finding a good workshop in Italy. Our experience of Italian workshops was good and they weren't too hard to pay either. 2008 Range Rover TDV8 435,000kms 2015 Range Rover L405 SDV8 Autobiography 2008 Ford Focus1.6 tdci Titanium DPF deleted |
Cheers riverstick,
Hi King,
If you are going to change the gearbox oil and filter when you renew the torque convertor it would be worth splitting the body of the oil filter and having a look for any collected debris on the underside ie inlet face of the filter element.
Hi Nicedayforit,
Okay Guys,
A suitable 'partner' for a Range Rover...a Westfalia horsebox...
Okay Guys,
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
Great write-up |
Like the cow |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Two things i would point out to you... Firstly, the rear callipers IMHO should simply be replaced. Not worked, lubed, played with ... Just replaced... I have just had a car in yesterday who was in for service 3 weeks ago (ok, an 06 SC so slightly different) and his brakes etc were checked as part of the service, he came in yesterday complaining of "a noise" and i kid you not, on stripping the rear brake out, the pads were down to metal... The disc was now 1/3rd of the thickness of the other side (which had less than half used pads in)
Hi Craig,
