Home > General > Mistake ? 2002 l322 v8
Page 1 of 3 123>
Paulmeds
England 2002 Range Rover HSE 4.4 V8 Baltic Blue
Hi, just bought 2002 l322 v8. Is my first range rover so didn't check as well as I should !!
After 1200 miles, needs all suspends up arms front rear replacing, new brakes, various small electrics faults folding mirrors cd changer etc.
But I love it, drives great, looks great but is it going to cause me problems ? Should I cut my losses and upgrade or stick with it ? Please help, thanks
Post #250304 24th Mar 2014 8:36pm
make a list of the problems you have and do a search for each on the forum..this should give you an idea whether you can do the jobs yourself or how much it will cost..
welcome btw.. ... - .- -.
Post #250306 24th Mar 2014 8:41pm
verydisco
it will drive much better with all the arms/bushings renewed.
Welcome to the club! Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #250323 24th Mar 2014 9:16pm
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Hi Paul - as Stan said, list the issues as many may be easy to sort with help on here.
Brakes are nothing like as expensive as you would imagine and an easy DIY job. 4.2 Supercharged Vogue SE
Post #250325 24th Mar 2014 9:21pm
WRUNH4
United Kingdom 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Welcome Paul, and have my sympathy as I am in a similar place Big Cry
6 months into ownership of '04 4.4 Vogue and I have replaced most of the audio/nav components, pads/discs, a suspension arm, rear-door weather seal, much of the cooling system (thermostats had gone and kept blowing the hoses off) and I still have the door mirror problems you mention! 2nd replacement amp fitted today, but the connectors were also corroded so they need replacing too... Maybe I have been a bit unlucky, the only problem I found when I bought it was a tyre getting to the end of it's life, so don't beat yourself up about inspection before buying Wink
I guess it depends on how much you love it - for me, it was a bucketlist entry to have one, but I could have ticked off several other entries for what I have spent so far!
More positively, there is lots of good advice on the forum and some fixes are not as spendy as they may first seem!!
Good luck with sorting your niggles Thumbs Up
Post #250326 24th Mar 2014 9:23pm
Suspension arms shouldnt be too expensive, and can be done by any local mechanic or diy if you have the kit. The brakes are fairly straight forward and there are many how to articles in the wiki. Just need to make sure the mechanic torques up the suspension when the car is on the ground
Bear with it and it could be a good un when sorted. Each job done is one less left to do!
They are heavy cars and will go through bushes and track rods with reasonable regularity 60-80k
As a new car to you, personally i would get a good service and have the gearbox serviced too. With all that you should he set for a fair few miles Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #250334 24th Mar 2014 9:44pm
Sandyt
As above and remember the jobs you do now don't have to be redone for a while. My last RR started its life with me on about 70k 9 years later it was still going strong bit like triggers broom but still going stick at it will work out - sounds like you already have the bug anyway Wink
Post #250342 24th Mar 2014 10:36pm
Paulmeds
Thanks everybody for your replies, getting the suspension etc done tomorrow costing £1700. Should also get a list of anything else they notice, so I will wait and see !!! Fingers crossed because I have def caught the bug !!
But if anybody can help with the most annoying niggle, drivers seat keeps going to a setting which has not been set. Have set all 3 memory's to same setting, have only one key so have set that also but if I lock it for short time the seat goes to wrong position. Does not seem to happen if left for longer times.
Thanks again for all the positive replys I really won't to stick with it.
Post #250531 25th Mar 2014 7:25pm
£1700 for some suspension arms seems very pricey, what exactly are they doing??? Pete
Post #250534 25th Mar 2014 7:39pm
Paulmeds
Hi, front rear upper lower suspension arms, some knuckles bushes on steering rack. Lots of play in front and can't adjust rear tracking as has seized. Lots of labour costs !!
Post #250543 25th Mar 2014 8:08pm
Oh right, quite a bit then.... it's the labour that kills you....
Mind you it should feel like a new car afterwards
Not long had my 2002, it's a bit of a fixerupper, got a couple of rear bushes on order from Dan, a few other faults to sort as well....
Don't you just love them!!!
Your seat sounds a bit weird, it's not a sticky button that gets touched as you slide out the seat???
Good luck with it, they are well worth it.. Pete
Post #250545 25th Mar 2014 8:18pm
Paul, seat will probably be the control/switch box on the side of the seat... Cheap ones to be found on the bay Thumbs Up
Post #250576 25th Mar 2014 9:49pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Paul,
Just to make you feel better, I bought a 2003 V8 4.4 in March 2010 after having a P38 for 11 years (and 3 classics before that), I paid £11500 for it (85,000 miles), and since owing it have paid out in the region of £18,500 on servicing / repair costs.
Main items have been:
Suspension Bushes (front & rear) - approx £2000
Gearbox rebuild - £3000
Alternator - £1200
Fuel Pump - £800
several batteries
Radiator and Trans Oil Cooler
You will find that Range Rovers know when you have some money in the bank, and they do something so that they can have it!
For example, ours is due for its MOT and service in April, 2 weeks back it decided that the drivers door window will go down, but refuses to come back up, and the nearside headlamp wiper is giving me 'the finger' - and I've pulled the fuse and done a reset, and it still sticks straight up!
Having said all that, both my wife and I still love it, and would not have anything else!
Post #250589 25th Mar 2014 10:12pm
Paulmeds
Pick the car up tomorrow from the garage, lots work done and will get a report of any problems found !! Fingers crossed.
Post #251020 27th Mar 2014 7:49pm
Chauch
I hope you get a fairly clean bill of health Paul and that you you are able to start enjoying it properly now Very Happy 4.2 Supercharged Vogue SE
Post #251021 27th Mar 2014 7:58pm
Page 1 of 3 123>
