![]() | Home > General > Mistake ? 2002 l322 v8 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35671 ![]() ![]() |
make a list of the problems you have and do a search for each on the forum..this should give you an idea whether you can do the jobs yourself or how much it will cost..
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
it will drive much better with all the arms/bushings renewed.
Chauch Member Since: 09 Feb 2014 Location: Beds Posts: 303 ![]() ![]() ![]() |
Hi Paul - as Stan said, list the issues as many may be easy to sort with help on here.
WRUNH4 Member Since: 30 Oct 2013 Location: United Kingdom Posts: 4 ![]() ![]() ![]() |
Welcome Paul, and have my sympathy as I am in a similar place |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Suspension arms shouldnt be too expensive, and can be done by any local mechanic or diy if you have the kit. The brakes are fairly straight forward and there are many how to articles in the wiki. Just need to make sure the mechanic torques up the suspension when the car is on the ground
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2280 ![]() ![]() ![]() |
As above and remember the jobs you do now don't have to be redone for a while. My last RR started its life with me on about 70k 9 years later it was still going strong bit like triggers broom but still going stick at it will work out - sounds like you already have the bug anyway |
Paulmeds Member Since: 18 Mar 2014 Location: Devon Posts: 34 ![]() ![]() ![]() |
Thanks everybody for your replies, getting the suspension etc done tomorrow costing £1700. Should also get a list of anything else they notice, so I will wait and see !!! Fingers crossed because I have def caught the bug !!
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8568 ![]() ![]() ![]() |
£1700 for some suspension arms seems very pricey, what exactly are they doing??? Pete
Hi, front rear upper lower suspension arms, some knuckles bushes on steering rack. Lots of play in front and can't adjust rear tracking as has seized. Lots of labour costs !! |
Oh right, quite a bit then.... it's the labour that kills you....
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
Paul, seat will probably be the control/switch box on the side of the seat... Cheap ones to be found on the bay ![]() |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1261 ![]() ![]() ![]() |
Paul,
Pick the car up tomorrow from the garage, lots work done and will get a report of any problems found !! Fingers crossed. |
I hope you get a fairly clean bill of health Paul and that you you are able to start enjoying it properly now |
