Home > General > Tdv6 or tdv8? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35267 |
depends on your budget but with the tdv8 you'll get an upgraded interior..
21st Mar 2014 8:28pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2564 |
TDV8 is leagues ahead of the TD6. |
21st Mar 2014 8:34pm |
paul r Member Since: 27 Feb 2012 Location: Nantwich Posts: 213 |
What about the MPG issue? |
21st Mar 2014 8:35pm |
If you want economy a Range Rover probably isn't the best choice in any case. TD6 spoils the car, TDV8 is better in every respect. |
21st Mar 2014 8:41pm |
I want the best economy that I can get...
21st Mar 2014 8:45pm |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 |
A Range Rover should have a V8 engine! Ideally petrol but if you have your mind set on Satan's fuel, let it at least be V8! |
21st Mar 2014 11:20pm |
found a nice TDV8. I'll keep you posted. |
21st Mar 2014 11:33pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7923 |
Test drive a TD6
21st Mar 2014 11:44pm |
Paul if you can go for a TDV8. there are a lot out there these days and low prices as well.
22nd Mar 2014 12:36pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
Nonsense... |
22nd Mar 2014 12:49pm |
I've seen one and made an offer on it. Haven't viewed yet, but I plan to get the train down on Friday, if its OK, ill drive back in it, if not ill have a train journey back! Where abouts do you live? Paul. |
22nd Mar 2014 3:55pm |
Next to Manc airport
22nd Mar 2014 6:12pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3739 |
I run a small fleet of Land Rovers and Range Rovers and can compare all the models back to back. There is very little difference between a JE remapped TD6 and a std 3.6 TDV8. A TD6 will do everything you want as long as you don't expect to drag race with it.
22nd Mar 2014 7:43pm |
It's this one: www.autotrader.co.uk/classified/advert/201...gcode=visc I've been put slightly off now though as it's advertised as overfinch, but the wheels aren't genuine and i'm not sure the bodykit/exhaust is. Also, I noticed that the overfinch lettering isn't spaced correctly...... Cheers, |
26th Mar 2014 7:46am |
