![]() | Home > Technical (L322) > Where's the Mic for the Handsfree? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
The grille next to your sunroof switch sir |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
Put a new microphone in mine as everyone I spoke to said it sounded like I was under water and they could not hear me. New mic, no problem (annoying as did work until 3 or 4 weeks ago)
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
There is an upgraded mic available from bmw. It's cheaper than the original too. |
Jammer600 Member Since: 31 Mar 2013 Location: Bath Posts: 212 ![]() ![]() |
Have you got a link? Are the easy to fit |
It took me about 2 mins to fit. Remove the black grill to the right of the overhead console, push out the centre grill, disconnect mic, remove mic from housing, clip in new mic, connect plug, push back the 2 grills and done.
TorontoDee Member Since: 27 Sep 2022 Location: Toronto Posts: 80 ![]() ![]() ![]() |
I'd like to upgrade the mic on a 2012 Supercharged. What's the part number? Any other directions/thoughts appreciated. 2012 Supercharged L322 |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3203 ![]() ![]() ![]() |
Nobody can understand a word I’m saying in my car either so I’d like to change the microphone in mine as well.
Anyone know if the plug is the same between LR038176 and XVC000050.
Doesn't look like it.
Iwheels Member Since: 26 Feb 2024 Location: Alberta Posts: 15 ![]() ![]() |
Is there any way to upgrade the XVC000050?
Is it that bad or do you just have a bad microphone?
David, why don't you swap the microphones and see if the problem moves vehicle? Im sure dad won't mind |
I did wonder about that but didn’t want to risk damaging anything in his car so I ordered a new one yesterday to collect this morning.
I've ordered a replacement. Told to expect a call Wednesday to head over and pick up at the Parts counter. 2012 Supercharged L322 |
