Home > Maintenance & Mods (L322) > Gearbox Oil and Filter Change change on a TD6 GM5L40E |
Semperfidlas Member Since: 27 Jul 2013 Location: Worksop Posts: 59 |
Hi All
12th Mar 2014 10:24am |
Hi All
12th Mar 2014 10:29am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3964 |
Easy job, get the filter, gasket and new bolts from Dan@Duckworths.
12th Mar 2014 11:01am |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 |
And buy a quality filter or else! Mine was a blue one! |
12th Mar 2014 1:05pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Make sure you can undo the filler before you drain the oil. |
25th Mar 2014 7:27am |
I wouldnt trust what LR say. ZF recommend servicing and they make the gearbox
25th Mar 2014 9:43am |
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 |
did mine at the weekend easy job ,i was on a lift,took about 2 hrs,you do not have to use texaco oil,i used millers sp 111,i rang them and this was the best oil they do ,i also rang the gearbox company in hilton and he said it is not special oil needed .mine seems smoother now. |
25th Mar 2014 2:58pm |
You have to remember "changing" the transmission oil on a GM 5L40E as fitted to a TD6 only changes about 6L out of a total capacity of 9.7L in the system ie about 60%.
25th Mar 2014 4:30pm |
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 |
I'll be doing mine soon and I plan to do 3 changes to really get it as close to all fresh as possible. My question is though, when do you change the filter? On the first or the last change? |
25th Mar 2014 4:34pm |
I changed my filter during the third change on the basis the first and second changes I considered as a flushing process.
25th Mar 2014 4:49pm |
Might have to put it to a pole!!! |
25th Mar 2014 5:45pm |
