Home > General (L405) > Rejecting a new L405
Page 1 of 3 123>
mucky61
United Kingdom 2013 Range Rover Autobiography 5.0 SC V8 Santorini Black
Has anybody rejected an L405 and for what reason.
Post #247136 8th Mar 2014 9:01pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
If you do a search there was a chap last month IIRC who successfully rejected one Thumbs Up
Post #247139 8th Mar 2014 9:34pm
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
Oh dear! Maybe worth a PM to The landrover customer services on here for advice if you think it's coming to that!
How bad is it?
Post #247150 8th Mar 2014 10:08pm
mucky61
Since new the suspension has made a knocking noise when going over uneven ground. Its a 2013 SC V8 Autobiography and its been back for all the upgrades to the suspension available, but it still makes the noise. JLR says its a 'characteristic' of the model. I'm not happy with that and have rejected it and to date both the Dealer and JLR aren't being helpful. i.e. They wont replace the vehicle or return the full purchase value.
Post #247198 9th Mar 2014 8:37am
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Do they all do that?
Does it say in the sales brochure "By the way the suspension knocks a bit off road"
Go and test drive another one and see if it's the same or ask to speak to someone whose owns one.
The vehicle is not fit for purpose and needs correcting/replacing or a full refund + out of pocket compensation.
Stick to your guns.......it's obviously causing you major stress on your hard earnt purchase.
Jonno
. 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #247201 9th Mar 2014 9:17am
stenh02
And defo give the LR customer services on here a heads up including your VIN number. He can check that all the TSBs have been carried out and maybe suggest some things. A different dealer perhaps.
Good idea about test driving another one on the bit of road you get the bumps on.
Given what you paid for the vehicle you would think they would be more understanding. Evil or Very Mad
Post #247202 9th Mar 2014 9:22am
joshydee
2002 Range Rover Vogue 4.4 V8 Stornoway Grey
Ive just posted in the customer relations section as im having the exact same problem. Dealer has tried 'the fix' and advised if it was still doing it then its a 'characteristic of the vehicle' Can't say im best pleased with that explanation. Sad
Post #247210 9th Mar 2014 10:33am
stenh02
Joshydee,
What model is that one? Your profile says 2002.
Cheers
Edit
Just read your thread on the LRCS. So, 4.4 TDV8 and 5.0SC have this fault.... All we need now is a 3.0 TDV6 for the full set and strengthen LRs argument of it being a characteristic...... Big Cry
Post #247216 9th Mar 2014 1:11pm
mucky61
The knocking noise happens when driving on the road usually when one front wheel is lower than the opposite. As for the affected model .. well the JLR Regional Tech Manager told me that I wouldn't be much happier having a replacement as it really only happens on the V8SC (not true), Oh and that maybe my expectations were too high. Well I can assure you if my salesman told me that when you give me 108K your car may or may not make a knocking sound. I would have clearly told him to poke it.
Post #247243 9th Mar 2014 6:37pm
campaj1
Relevant case for you: Lamarra v Capital Bank. Car of this calibre should be 'free from minor defects'.
Also Rogers v Parish.
Both cases pertaining to Range Rovers.
Shout if ntk more.
Post #247248 9th Mar 2014 7:06pm
RR2008HSE
I can't afford a new L405, but if I could, my expectations would certainly be very high.
Post #247298 9th Mar 2014 11:16pm
Hotwheels
United Kingdom 2013 Range Rover Vogue SE TDV6 Fuji White
If it's so "characteristic" then you should be made aware by the salesperson before you buy (if a man, who has or professes to have special knowledge or skill, makes a representation by virtue thereof to another by words or by conduct....with the intention of inducing him to enter into a contract with him, he is under a duty to use reasonable care to see that the representation is correct, and that the advice, information or opinion is reliable) also sale of goods act, repair/replace/refund inc costs. I would compare with another one, go to another dealer and request an extended test drive on your own, or have an independent report done as this will be more useful to a judge if it goes that far, they may say the car is "within tolerance" however you can argue that!!!!
Post #247322 10th Mar 2014 9:45am
CaptainG
United Kingdom 2013 Range Rover Autobiography SDV8 Luxor
I have a 4.4SDV8 A/B and can confirm the same noise, has been for all the mods they know about but it has made no difference, have also test driven 2 other A/B cars and the noise is exactly the same,
It does appear that this is a "Characteristic" of the car as Land Rover and dealers are saying,
I beleive this is a major design issue and JLR need to address this urgently, other than the annoying rattle I would be very happy with this car, I am also discussing the possibility of rejection with the dealer, JLR have offered to extend the warranty to 5 years but not sure if I can stand the rattle.
Would not be so bad if they openly admitted they had a problem and that it will be sorted ~ after spending over £100k I would expect better.
Post #247372 10th Mar 2014 3:09pm
campaj1
you have PM
Post #247398 10th Mar 2014 6:00pm
fmb123
mucky,
see my post here http://www.fullfatrr.com/forum/topic23358.html we have had endless problems. and since getting it back after they had it in to fix described problem, new ones have recently arisen and old ones come back. going back on thursday. starting to consider what option we have, and have advised the dealer rejection is a possibility if not resolved this time. 2017 L405 Range Rover TDV6 Corris Grey
1988 3.5 Range Rover Classic
1993 4.2 Range Rover Classic LSE
Post #247420 10th Mar 2014 7:41pm
Page 1 of 3 123>
