Home > Maintenance & Mods (L322) > Jacking up with electric side steps |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6370 |
In the owners manual it says you have to remove the electric side step before you jack it up.
6th Mar 2014 1:20pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35343 |
found this in an old thread, any help?
6th Mar 2014 1:34pm |
Thanks Stan, I already knew about how to lock them out, but I was hoping someone will have real life experience of this and be able to tell me if I've actually got to take the things off just so I can get my wheel balancing checked. Seems SUCH a faff! Discovery 4 HSE
6th Mar 2014 1:37pm |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 |
My dealer said you have to leave one of the doors on the side you want to lift up the vehicle ajar. This prevents the side step from retracting. No problem to lift the car with the side step like this. |
6th Mar 2014 3:13pm |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
I would just lock them out. I can't see a problem after that. 2020 Porsche Panamera Turbo Hybrid (V FAST)
6th Mar 2014 9:02pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Adam, yes you are correct. The scissor jack would hit the step... Only problem is, after a couple of years the steps corrode on because no one uses grease anymore in this world!!! |
6th Mar 2014 9:11pm |
I've had the steps retracting when they were supposedly in the lock position. If the door is ajar, they won't retract. |
7th Mar 2014 6:57am |
When i lock them out to go on my 2 poster ramp, i not only lock them out but open the rear door's, click the latch over with a screwdriver and press the lock button (on the door card) down for safety... That way the rear door cannot be closed by accident.
7th Mar 2014 8:16am |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
I've jacked mine up with the steps locked out using a bottle jack in the jacking points. Not much room to work the jack handle up and down but it works fine. 2012 5.0L S/C
7th Mar 2014 8:31am |
I think everyone is missing the original point... The op said the steps should be removed when using the scissor jack that comes with the car,,, |
7th Mar 2014 8:33am |
i tend to jack mine up with a trolley jack in from the back or the front, if done this way you could leave the steps alone.. ... - .- -.
7th Mar 2014 8:45am |
Stan, do you put the jack under the lower suspension arms rather than the official jacking points?
7th Mar 2014 10:29am |
yes mate.. ... - .- -.
7th Mar 2014 10:33am |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 |
Anyone have a picture of the 'suspension arm' to place trolley jack? |
20th Sep 2014 12:45pm |
