Home > Maintenance & Mods (L322) > Adaptive/Cornering Lights & DRL Wiring
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
I have had the adaptive/cornering headlights that came in my FFRR refurbished as they were leaking and had LEDs added at the same time and fitted all new bulbs (except xenons)
I have tried to get the adaptive bits to work without success as far as I can tell. I have tried lights on and in auto with car in P, D and N indicators on and off an turning the wheel lock to lock but the extra lights do not illuminate. One of the lights does show signs of minor melting (was there when purchased) so could the previous owner have turned them off (I have checked using my iid but no obvious option for turning on/off).
If I knew it would fix it I would buy a new module but don't ant to spend a couple of hundred if not needed or if it won't fix the problem.
All other lights work fine as far as I know with the possible exception of the puddle lights in the door mirrors.
I tried to wire the LED DRLs as per the instructions from the supplier (wire to connection in box in left of engine bay) but although this got the lights working I also got all sorts of warnings for reduced power etc... on the dash which went when I removed the wiring so don't really want to wire them there as a running car is more important than the DRLs.
Does anyone know of an alternative and safe connection to pick up power for the DRLs ideally outside the big box or one where I can just fit an extra spade fuse via an adaptor to an existing fuse. If not which wire is the side light and I will look at possibly linking the LEDs t them although this is the second choice.
Any help suggestions appreciated. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #244129 21st Feb 2014 7:46pm
i'd connect the drls to a drl switch which you can get of ebay for around a tenner, where to wire up to can be found if you do a forum search..
Post #244147 21st Feb 2014 9:57pm
rej
Not 100% sure from the search but I think I need something like this http://www.ebay.co.uk/itm/DRL-Daytime-Runn...233540bff9 wired to the battery terminals and the LEDs. Hopefully this won't result in reduced engine performance.
Had a similar unit built into my DRLs fitted to my old Pathfinder which worked ok and dimmed the DRLs when also connected to the side lights.
Still need help on the adaptive/cornering lights not working There is a difference between knowing your sh!t and knowing you're sh!t
Post #244157 22nd Feb 2014 12:10am
that ebay one is a bit different to what i have at the moment..my hybrid fogs are wired to the ignition feed so the drls come on when started but its also wired to he headlight feed so when the dipped headlights are switched on the drls go off..
Post #244191 22nd Feb 2014 9:49am
T24RES
Where did you get those Stan ? Ian
Post #244205 22nd Feb 2014 11:21am
supplied by Craig [CTC]
Post #244221 22nd Feb 2014 12:34pm
T24RES
Roger Thumbs Up Ian
Post #244248 22nd Feb 2014 3:11pm
rej
DRL fitting sorted hopefully with an ebay link direct to the battery.
Still looking for help with the Adaptive/Cornering lights. For information the warning lights comes on for a couple of seconds when the car is started along with the airbag and brake warning etc... then goes out. Trying to work out if the Adaptive/Cornering lights are working (head lights and main beams work fine) or if maybe they have been turned off. No obvious light related codes from IID.
Build sheet indicates that it has "Adaptive Headlights BiXenon [064DI]" and lights have the extra bulb in with the side light (has worked at some stage as minor melting of surround).
Post #244960 26th Feb 2014 9:54am
T24RES
Mine did this when the battery was low. Check the voltage after the car has gone to sleep. Does it show the warning every start up or just the first one ? Ian
Post #244983 26th Feb 2014 11:47am
rej
Battery shows a good charge and no other problems. The light only comes on with the other normal warning lights to show that they are working and then they go off, as far as I know they come on and off every time the ignition goes from off to position II. There is a difference between knowing your sh!t and knowing you're sh!t
Post #244995 26th Feb 2014 1:27pm
rej
LED around the headlights wired up via a £10 switch directly to the battery. Also Main beam turned on as DRL via IID Tool. Now just need to sort the cornering lights to see if I can get them working or find out if they are. There is a difference between knowing your sh!t and knowing you're sh!t
Post #247423 10th Mar 2014 6:47pm
rej
Any ideas on how to get the cornering lights to work???? There is a difference between knowing your sh!t and knowing you're sh!t
Post #247776 12th Mar 2014 2:28pm
are the new bulbs you fitted ok.. ... - .- -.
Post #247777 12th Mar 2014 2:34pm
rej
The bulbs are OK as far as I know, but the lights don't come on with the replacements I fitted or the originals that where in the units when I bought the car. The original bulbs looked ok (i.e. no broken filaments) and the new ones are LED.
Stan, I also got an email notification saying you had commented "are you sure you have them.." but can't see this on the post???. Is there a simple way of confirming 100% if I have the cornering light set up as opposed to a PO having just fitted the headlight units in the past. There is a difference between knowing your sh!t and knowing you're sh!t
Post #247785 12th Mar 2014 3:13pm
ok, this is what a cornering light should look like, led is the side and the halogen is the cornering light..
Post #247788 12th Mar 2014 3:32pm
