Home > Maintenance & Mods (L322) > Adaptive/Cornering Lights & DRL Wiring
Vogue
you might have the bulbs but are they wired in - the holders were there for all headlights in 06MY on, but not all were wired in to come on - only on select models
Post #247795 12th Mar 2014 3:59pm
n1cktdv8
Ah.....mine dont work....but bulbs are there.....bulb check I think ! Is this where I put the car details and a bit about myself ?........
Post #247796 12th Mar 2014 4:01pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Mine had the bulbs in and look like they have worked at sometime as the surround has melted a little bit.
Also they have the two ballasts that my other spare set if lights with the blanking plate where the bulb goes doesn't have
 There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #247801 12th Mar 2014 4:12pm
Vogue
you need to check the power supply as there may not be one there - frequently headlamps are swopped s/h from other vehicles by previous owners which could explain why it looks like they have worked but don't
Post #247805 12th Mar 2014 4:39pm
rej
It this just a case of sticking a circuit tester in the pins on the connector, if so how do I turn them on to get power to the connector.
Apart from the bulbs are there any other things to check to see if they were fitted, what would it be called on the spec sheet as that says bi-xenons. I have the orange adaptive light warning light on the dash that comes on for a few seconds when I start the engine up.
I did see mention of lighting modules going bad and stopping the lights working but don't want to get a new one just for the sake of it especially if I never had the option. There is a difference between knowing your sh!t and knowing you're sh!t
Post #247808 12th Mar 2014 5:01pm
