Home > Technical (L322) > Gearbox failure? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 969 |
Does he mean the Hill Descent Control light i.e. right hand of the three round lights between the speedo & rev. counter or the Low Range Indicator light (i.e. to the right of PRND) which is flashing?
19th Feb 2014 9:10pm |
texpis Member Since: 29 Nov 2010 Location: Stockton-on-tees Posts: 53 |
Hi and thanks for the reply Phil. Went to have a look today there weren't any flashing lights when I tried it and the guy wasn't there so not sure about that bit. Started it put into drive and a horrendous grinding noise like you had missed a gear in a manual only louder.
20th Feb 2014 10:12am |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2581 |
Not sure of the age of your friends FF but sounds like the front diff which was a recall a few years back on early cars, symptoms sound exactly like mine when the diff went |
20th Feb 2014 10:25am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
+ 1 sounds like a diff to me... |
20th Feb 2014 10:29am |
....and me |
20th Feb 2014 10:34am |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 316 |
Very easy, look under your car (your friend inside the car, foot on brake!!) to the black propshaft, which is from transferbox to the front differential, your friend makes D in gearbox and you will see, if the propshaft is moving, when it moves, the differential part is defect. You can buy the part at island4x4, look here: http://www.island-4x4.co.uk/front-diff-spl...-1543.html , and also the new propshaft, former times was on warranty...., best rgs, uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
20th Feb 2014 10:55am |
I will try that but the problem I see is it won't even go into gear without making this noise the second I get it near reverse without any movement of the car.
20th Feb 2014 11:56am |
What we’re saying is :
20th Feb 2014 1:04pm |
Ha cheers Phil and others always nice to see a pic
20th Feb 2014 3:49pm |
Unfortunately the Torsen centre differential can only ‘bias’ the torque up to a maximum split of 65%/35% to either the front or rear – it can’t lock. If your front propshaft sees zero torque (i.e. it’s spinning) then unfortunately the rear propshaft will see zero torque too. You won’t get the car to move under its own steam I’m afraid.
20th Feb 2014 4:46pm |
Cheers Phil when I saw your pic of the centre diff I thought that would be the case.
20th Feb 2014 6:29pm |
We'll done chaps 10 out of 10
21st Feb 2014 10:26am |
Call a main dealer, they will be able to tell you, I blagged mine about 2 years ago however I think I was one of the last, good luck |
21st Feb 2014 10:30am |
@texpis, if there is no warranty from LandRover, you can buy cheap part with the Name: "Front DiffSplined Coupling Joint DA2355", together with propshaft TVB500290, good luck! and: my link runs.... L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
21st Feb 2014 12:06pm |
