Home > Technical (L322) > Gearbox failure?
texpis
England 2002 Range Rover HSE 4.4 V8 Alveston Red
Gearbox failure?
Hi did a quick search because I am sure this will have come up before but to no avail. A friend has a 2003 diesel range rover L322, he lost all drive last night.
His hill decent light is flashing and when he puts it in gear he can hear a crunching from the gearbox. I know an a standard 4x4 the dif can cause loss of drive but with the viscous centre dif that shouldn't be a problem.
I have not seen the car yet to confirm anything going to look Friday, it's a very low milage but has not had any gearbox oil changes.
There has been no other warning lights or symptoms just loss of drive. I will check for fault codes when I go round on Friday anything specific I can check for.
Thanks. Mick
Post #243632 19th Feb 2014 2:43pm
RRPhil
Does he mean the Hill Descent Control light i.e. right hand of the three round lights between the speedo & rev. counter or the Low Range Indicator light (i.e. to the right of PRND) which is flashing?
It’s possible that the transfer box is stuck between ranges (there’s a neutral position between high & low to allow the vehicle to be towed on its wheels). It might be worth your friend trying the Fuse 37 trick to recalibrate his shift motor:
By the way, the centre diff. is a Torsen unit, rather than a viscous coupling, in the NV225.
Phil
Post #243684 19th Feb 2014 9:10pm
texpis
Hi and thanks for the reply Phil. Went to have a look today there weren't any flashing lights when I tried it and the guy wasn't there so not sure about that bit. Started it put into drive and a horrendous grinding noise like you had missed a gear in a manual only louder.
Tried the procedure below the transfer neutral came up on dash and I could here the motor moving but still grinding in high or low.
I did try with the transfer box in neutral and the grinding was gone, I guess that points me to the transfer box?
There are no fault codes logged.
Mick
Post #243780 20th Feb 2014 10:12am
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Not sure of the age of your friends FF but sounds like the front diff which was a recall a few years back on early cars, symptoms sound exactly like mine when the diff went Thumbs Up
Post #243782 20th Feb 2014 10:25am
+ 1 Thumbs Up sounds like a diff to me... Thumbs Up
Post #243783 20th Feb 2014 10:29am
RRPhil
....and me Thumbs Up
Post #243784 20th Feb 2014 10:34am
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Very easy, look under your car (your friend inside the car, foot on brake!!) to the black propshaft, which is from transferbox to the front differential, your friend makes D in gearbox and you will see, if the propshaft is moving, when it moves, the differential part is defect. You can buy the part at island4x4, look here: http://www.island-4x4.co.uk/front-diff-spl...-1543.html , and also the new propshaft, former times was on warranty...., best rgs, uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #243786 20th Feb 2014 10:55am
texpis
I will try that but the problem I see is it won't even go into gear without making this noise the second I get it near reverse without any movement of the car.
Mick
Post #243797 20th Feb 2014 11:56am
RRPhil
What we’re saying is :
The transmission is fine
The transfer box is fine
The spline has gone on the front propshaft which connects the transfer box to the front differential so the front propshaft is turning when you engage drive or reverse even though the vehicle isn’t moving. The noise that you can hear is coming from what is left of the spline teeth grinding against each other as they try to engage.
If you look under the stationary vehicle with the engine running while someone engages drive (with their foot on the brake) you will be able to see the propshaft turning if this is the issue.
Phil
Post #243821 20th Feb 2014 1:04pm
texpis
Ha cheers Phil and others always nice to see a pic Smile
If it's the diff is there a way I can drive it on the old landrovers I could disconnect the prop put in diff lock and drive, I need to get it to my garage.
Mick
Ps meerbush your link does not work
Post #243850 20th Feb 2014 3:49pm
RRPhil
Unfortunately the Torsen centre differential can only ‘bias’ the torque up to a maximum split of 65%/35% to either the front or rear – it can’t lock. If your front propshaft sees zero torque (i.e. it’s spinning) then unfortunately the rear propshaft will see zero torque too. You won’t get the car to move under its own steam I’m afraid.
Phil
Post #243854 20th Feb 2014 4:46pm
texpis
Cheers Phil when I saw your pic of the centre diff I thought that would be the case.
Mick
Post #243884 20th Feb 2014 6:29pm
texpis
We'll done chaps 10 out of 10 Very Happy
Couple of questions, it doesn't look like its had the diff recall done is this still live, I heard somewhere it wasn't.
Is just changing the splined bush and drive shaft straight forward I read something about a crush washer?
Mick
Post #243973 21st Feb 2014 10:26am
Rosco
Call a main dealer, they will be able to tell you, I blagged mine about 2 years ago however I think I was one of the last, good luck Thumbs Up
Post #243974 21st Feb 2014 10:30am
Meerbusch
@texpis, if there is no warranty from LandRover, you can buy cheap part with the Name: "Front DiffSplined Coupling Joint DA2355", together with propshaft TVB500290, good luck! and: my link runs.... L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #243994 21st Feb 2014 12:06pm
