Home > Maintenance & Mods (L322) > Potential Dashboard Renewal looms....
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
Last weekend, MrsC managed to snap the clip which holds the sunvisor in place. Not such a big deal, you may think, one screw later it's replaced. However.....she failed to catch the broken piece, meaning that the small bit of plastic flew across the dash and disappeared. I wasn't in the car so I don't know whether it went in the heater vent for the screen, or right down the back of the dash, between the dash and the screen. What I do know, however, is that every time you go round a corner, the little piece of plastic rattles it's way from one side to the other Rolling Eyes
I'm going to have a go at picking it out with a piece of coathanger and some grease but I'm not optimistic. so you can guess my next question - how do I, and how much do I, remove the dash to get it out? I've had the dash top off before but I can't recall how much was visible from there (not much I suspect) and what else needs to come out.
Well aware that this will be a very significant task....
Thanks.
Post #242279 12th Feb 2014 5:18pm
by coincidence mine broke as well but my 'bit' fell neatly into the drink cubby holder thingy on the centre console...
can t help with your problem except to say dont go round corners... Mr. Green ...
Post #242281 12th Feb 2014 5:34pm
Googsy
Straight forward enough. You need to disconnect battery first because of airbag. Start at both ends where your walnut vents are. At the side of these there is a panel and you need to prise these off. Once off you will see screws that hold vents in place. You need to push in the little clips on the chrome part of the vent and remove to access another couple of screws. Once vents are removed you just need to remove screws on top of dash. There is a video on powerful that shows you. Fairly easy job. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #242282 12th Feb 2014 5:37pm
Cappo
Thanks Googsy. I've done that part before, to fit an aux transceiver to the radio. It's when I get the dash top off and find that I need to go further that I'm worried about! The gap between the screen and the screen vents won't be open just by removing the dash top, I don't think??
Post #242303 12th Feb 2014 7:02pm
supershuttle
Although I've not done this a small rubber pipe jury rigged to a vacuum cleaner gives suction powerful enough to pick up small bits and pieces even bolts and being a flexible thin pipe you might be able to get it in to the tightest corners. Geoff
Post #242304 12th Feb 2014 7:17pm
What about something sticky, like fly paper, a lump of something on a stick... You get the idea...
Push it into the vent and leave it there. Hopefully, with normal driving, it will catch it eventually... Previously..
Post #242316 12th Feb 2014 8:01pm
Cappo
Great thanks, I like those ideas, will give it a try Smile
Post #242478 13th Feb 2014 1:49pm
sleepezy
happened to me - after a couple of months of rattling around it finally found a new home and hasn't been heard since
Post #242538 13th Feb 2014 6:10pm
Trev18
United Kingdom 2005 Range Rover Vogue SE Td6 Zambezi Silver
Nice explanation..... Sleepezy...
But what's happened about the bit of plastic...... !!!!!!!!!! Laughing Laughing Laughing Whistle Current Cars
(Sold) Range Rover TD6 05 Vogue SE - 85k - Zambezi Silver - Black Leather..
Kia Ceed (4) 1.6 - 33k - Silver
Previous.
VW Golf 2008 2.0 SDI (With Add Ons) - 109k Silver
Vauxhall Zafira 2.2 Petrol SRI - with Ex Pack 32k -Turquoise (traded for the FFRR)
Post #242553 13th Feb 2014 7:32pm
One of the kids lost a pen down the vents in the mrs Skoda.......
Didn't tell me.....
Wound up with a loud clicking noise when the fan was on. The biro had lodged itself in the fan itself.
Thank god for German engineering the fan unit just dropped out of the bottom of the dash with a twist and out came the biro Thumbs Up much easier than expected..
As for the bit of plastic, have you tried setting the fans to full, shutting the vents and putting it in "up" only, then driving round a lot of bends. Never no it may fly out.... Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #242570 13th Feb 2014 9:38pm
