Home > Maintenance & Mods (L322) > Potential Dashboard Renewal looms.... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
by coincidence mine broke as well but my 'bit' fell neatly into the drink cubby holder thingy on the centre console...
12th Feb 2014 5:34pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Straight forward enough. You need to disconnect battery first because of airbag. Start at both ends where your walnut vents are. At the side of these there is a panel and you need to prise these off. Once off you will see screws that hold vents in place. You need to push in the little clips on the chrome part of the vent and remove to access another couple of screws. Once vents are removed you just need to remove screws on top of dash. There is a video on powerful that shows you. Fairly easy job. Present :2008 TDV8 HSE
12th Feb 2014 5:37pm |
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 |
Thanks Googsy. I've done that part before, to fit an aux transceiver to the radio. It's when I get the dash top off and find that I need to go further that I'm worried about! The gap between the screen and the screen vents won't be open just by removing the dash top, I don't think?? |
12th Feb 2014 7:02pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3824 |
Although I've not done this a small rubber pipe jury rigged to a vacuum cleaner gives suction powerful enough to pick up small bits and pieces even bolts and being a flexible thin pipe you might be able to get it in to the tightest corners. Geoff |
12th Feb 2014 7:17pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
What about something sticky, like fly paper, a lump of something on a stick... You get the idea...
12th Feb 2014 8:01pm |
Great thanks, I like those ideas, will give it a try |
13th Feb 2014 1:49pm |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 |
happened to me - after a couple of months of rattling around it finally found a new home and hasn't been heard since |
13th Feb 2014 6:10pm |
Trev18 Member Since: 23 Apr 2013 Location: North Manchester UK Posts: 267 |
Nice explanation..... Sleepezy...
13th Feb 2014 7:32pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8621 |
One of the kids lost a pen down the vents in the mrs Skoda.......
13th Feb 2014 9:38pm |
