Home > Maintenance & Mods (L322) > Cleaning your inlet manifold with Mr. Muscle? |
misteralz Member Since: 30 May 2012 Location: Aberdeenshire Posts: 148 |
http://scottishvag.net/viewtopic.php?f=101&t=96231
19th Jun 2012 8:48am |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
I read about this recently as I was getting a "police siren" type sound coming from my turbo, due to the VNT vanes sticking.
19th Jun 2012 9:24am |
BTW It's the exhaust manifold |
19th Jun 2012 9:59am |
D'oh! Hell, clean the inlet manifold as well while you're there... |
19th Jun 2012 12:01pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 |
Nice website address too, (scottishvag) anything to do with Mick's porn empire? .
19th Jun 2012 3:12pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
VAG - Very Attractive Girl Land Rover Addict
19th Jun 2012 3:17pm |
yorkie3259 Member Since: 29 Apr 2012 Location: Bridgwater Posts: 9 |
Has anyone tried this yet or any of the commercial turbo cleaners on the market.
5th Feb 2014 2:46pm |
It's done on the exhaust side, not inlet. As mentioned the crud would end up in the cylinders, not good. |
5th Feb 2014 3:58pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
Where exactly do you inject the Mr Muscle? |
5th Feb 2014 4:02pm |
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 |
http://www.powerenhancer.co.uk/product.php...bo-cleaner
5th Feb 2014 4:16pm |
^ That seems more sensible |
5th Feb 2014 4:33pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
It's into the EGR feed pipe - e.g. the other end from the EGR valve so it's basically de-coking downstream of the exhaust manifold. You're right it would be nuts to do this at the EGR valve and let all that carbon build up enter the engine, never mind letting mr muscle go to work on your cylinder liners and valves or potentially bending a rod with mr muscule filling a cylinder. I'd much rather use a dedicated fuel additive myself, as recommended by tbonner001, but I can't fault the logic of the idea. What'll it do to your turbo bearings though? |
5th Feb 2014 4:38pm |
The EGR bye-pass pipe is a possibility but you would either have to have the EGR blanked off or disconnect the vacuum hose so the valve was hopefully fully closed. If not you still have a distinct possibility of passing a quantity of Mr Muscle thro the engine.
5th Feb 2014 7:39pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 |
if you used Mr Muscle, your engine could go Cillit BANG! |
5th Feb 2014 11:08pm |
