Home > Maintenance & Mods (L322) > Cleaning your inlet manifold with Mr. Muscle?
misteralz
Scotland 2003 Range Rover Vogue Td6 Buckingham Blue
http://scottishvag.net/viewtopic.php?f=101&t=96231
Well worth a read! Anyone ever done something similar? I'll be deleting the EGR on my L322 when I pick it up and figured doing this would be easier than taking the inlet manifold off to clean it all up. I don't think there's any chance of hydrolocking the engine as Mr. Muscle's crazy foamy - it's not like I'm pouring Coca-Cola down the inlet manifold. Whistle
Post #126813 19th Jun 2012 8:48am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I read about this recently as I was getting a "police siren" type sound coming from my turbo, due to the VNT vanes sticking.
After a couple of garages suggesting I had to have a new turbo (mucha £££'s), I decided to give it ago, now not suggesting that I have had an instant transformation, but the sound is a lot more subdued.(I only carried it out yesterday)
It was either strip down the turbo and decoke or use Mr Muscle, so chose the easier route.
If I could have got to actuator on the side of the turbo to "work it", this may have freed up the mechanism more.
Post #126816 19th Jun 2012 9:24am
Richcl
BTW It's the exhaust manifold Smile
Post #126817 19th Jun 2012 9:59am
misteralz
D'oh! Hell, clean the inlet manifold as well while you're there... Laughing
Post #126831 19th Jun 2012 12:01pm
Nice website address too, (scottishvag) anything to do with Mick's porn empire? Laughing .
Post #126856 19th Jun 2012 3:12pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
VAG - Very Attractive Girl Wink Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #126857 19th Jun 2012 3:17pm
yorkie3259
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
Has anyone tried this yet or any of the commercial turbo cleaners on the market.
is this £40 for a can of Mr Muscle
http://www.ebay.co.uk/itm/Diesel-Turbo-Cle...3a8a1f3ab4
looks like it Do I really have time to tinker with one of these
Post #239983 5th Feb 2014 2:46pm
Am I missing something here? Confused
Surely if you remove the EGR Valve on a TD6 and inject Mr Muscle into the inlet manifold the Mr Muscle will loosen / disolve all the carbon and oil crap in the inlet manifold which when you start the engine will then be drawn thro the engine cylinders and out thro the exhaust manifold and exhaust.
It may well clean the turbo on the way thro (possibly) but what about all the detritus going thro the engine?
Would you not have to remove the inlet manifold first, before injecting Mr Muscle, and clean it out manually thereby removing any risk of damage?
Post #239992 5th Feb 2014 3:51pm
Richcl
It's done on the exhaust side, not inlet. As mentioned the crud would end up in the cylinders, not good.
Post #239995 5th Feb 2014 3:58pm
Where exactly do you inject the Mr Muscle?
Post #239998 5th Feb 2014 4:02pm
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
http://www.powerenhancer.co.uk/product.php...bo-cleaner
safer and it works Far to many gone...
Post #240003 5th Feb 2014 4:16pm
^ That seems more sensible Thumbs Up
Post #240005 5th Feb 2014 4:33pm
It's into the EGR feed pipe - e.g. the other end from the EGR valve so it's basically de-coking downstream of the exhaust manifold. You're right it would be nuts to do this at the EGR valve and let all that carbon build up enter the engine, never mind letting mr muscle go to work on your cylinder liners and valves or potentially bending a rod with mr muscule filling a cylinder.
I'd much rather use a dedicated fuel additive myself, as recommended by tbonner001, but I can't fault the logic of the idea. What'll it do to your turbo bearings though?
Post #240007 5th Feb 2014 4:38pm
The EGR bye-pass pipe is a possibility but you would either have to have the EGR blanked off or disconnect the vacuum hose so the valve was hopefully fully closed. If not you still have a distinct possibility of passing a quantity of Mr Muscle thro the engine.
Personally I wouldn't risk it and would go for the alternative additive solution.
Hopefully I never have to do either. Smile
Post #240052 5th Feb 2014 7:39pm
johnboyairey
if you used Mr Muscle, your engine could go Cillit BANG!
Post #240203 5th Feb 2014 11:08pm
