Home > General > Just seen this on A/Trader
Dozzer
When you say a little expensive Dan lets say the motor is "as described" and no niggles.... What would you say was a fair offer... Anyone else please feel free to chip in with what you think its worth Thumbs Up
PS: I've looked at a few to date and let's say "less than described" comes to mind although to be fair one mans mint is certainly not mine so far. I might be coming across as a PITA but the word mint was used in both adds.
Post #239351 3rd Feb 2014 8:27pm
dan_uk_1984
PM'd you Wink
Post #239352 3rd Feb 2014 8:28pm
peterg1965
All a little cloak and dagger!
Post #239357 3rd Feb 2014 8:41pm
peterg1965
LAND ROVER
RANGE ROVER ESTATE4.4 V8 VOGUE 4dr Auto (ID:22606)Valuation Reference:MAN5-LMSM-GB48
Miles :82500 (03/02/2014)
Date of Registration:April 2003
Trade In Clean£6,400 - £6,825
Trade In Average£5,950 - £6,350
Trade In Below£5,450 - £5,825
Figures above are CAP prices for trade in, so I suspect the asking prices is probably £1000 too steep.
Post #239359 3rd Feb 2014 8:46pm
mjdronfield
We'll I paid a bit over the odds for mine, but it was a one owner car and I got 12 months warranty, which I have renewed each year......
That green is Epsom green by the way, same as mine.
Don't discount it if it ticks all your boxes........and is what you want.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #239361 3rd Feb 2014 8:48pm
Dozzer
I'm sure there would have been some movement on price, totally get where your coming from Thumbs Up
Post #239370 3rd Feb 2014 9:30pm
Dozzer
Ok I've managed to make contact with the seller who comes across as a decent guy and very open to all of my questions. Just a few niggles identified at this stage:
- Steering column telescopic operation not working, tilt is fine
- Folding mirrors work fine but the n/s clicks (sticks slightly) in operation
- Drivers electric seat button/leaver is cracked - just needs replacement
- Usual drivers seat squab slightly flat - replace.
- Small rust bubble on rear hatch - straight forward fix for me.
Only one that bothers me is the column operation - straight forward or motor replacement? Anyone any experience with this issue.
Post #239418 3rd Feb 2014 10:16pm
mjdronfield
Never had the issue, but I understand sometimes the thread that turns to move the colum sometimes comes out the female part, so when it turns, nothing happens.
There is also a plastic part that breaks, that a member on here had redone in metal.....
Have a quick search.
Check the rear arches on the lip - they all rust there as it's steel and not protected properly.
The second set of wheels could be useful with snow or mud tyres fitted.
I'm in chesterfield if you need any pointers.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #239434 3rd Feb 2014 10:33pm
johnboyairey
rest assured that if you service your Porsches, you'll know how to fix a BMW which essentially these are.
the price is a personal thing, but to fix these cars you just need internet forums like here.... and a diagnostic tool to keep you on top of most things. these are about £300.
the steering column is a sort of delicate subject. the plastic fixed nut on either the up/down, or in/out break away if I remember correctly. it can be fixed by putting a pair of lock nuts against each other - failrly simply. and the regular auto op. of the column when you put key in, can be disabled with your diag. tool. -to stop it wearing out! parts for that column come in very expensive if bought new, but its just a couple of weird nuts, that cause most issues. and maybe a worn out motor. I buy as many secondhand parts as I can to keep mine running, (not a huge no of parts changed mind you) but buy original service parts new when I can.
the engine is a near bullet proof design, but watch out for coolant leaks. the timing chain guides are the weak point. find out if you purchase has had these done. listen to engine at cold and warm tickover, no clattering and perfect idle is normal. lastly find out if the gearbox has been reconditioned, that is another major plus point. after that, its quite straight forward, and parts are fairly plentiful now for these older models.
you WILL enjoy your car, and wonder why you didn't buy one ages ago!
going off topic here, but think favourably about buying a petrol engine car (early model) with a good make of LPG already fitted. they may go for slightly more money, but they run perfect. (around half the cost too!) -I have same. see lpg section on here.
finally, if you see one with damaged doors front wings bumpers etc, these can also be found quite easily secondhand, in same colours, superb condition, and are easy to replace.(I had a bare door couriered to me, and perfect!) bumpers are cheaper still as people dispose of the early ones very cheap after upgrading to newer style 'conversions'
Post #239540 4th Feb 2014 11:16am
Dozzer
Thanks for the in depth reply, very useful. Yes I conduct the majority of work myself and a diagnostic tool would be first on the list Thumbs Up
Post #239587 4th Feb 2014 2:56pm
