![]() | Home > Maintenance & Mods (L322) > Rear Arches - How long before corrosion returns |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
I'd just bounce it back to the dealer and tell them to do it properly. Repair should be invisible once they've finished - and if there is rust they should cut out the rusty metal and weld a new piece in. |
Thanks... bit embarrassed to take it back after all the issues we had with the car to start with... it's still a warrantied repair right enough. Just wondered if others had it come back and it was something to 'keep an eye on but live with' Thanks |
I wouldn't be living with it I'm afraid. Either they do a proper job or they get it back. |
You can stop the corrosion coming back thro from the rear by simply coating the rear surface of the arches with a liberal coating of general purpose grease.
Thanks Simes and NDF... |
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 ![]() ![]() ![]() |
The dealer will get payment from landrover and it should be perfect. Complain take it back and tell them this it will be in there best interest to sort it out |
@pld 118
Great reply NDF, thanks very much.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7878 ![]() ![]() ![]() |
I had mine tidied up and then fitted the wheel arch protectors from other models, that we're never fitted to the L322.
Thanks Mark,
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8692 ![]() ![]() ![]() |
There isnt a strip fitted as standard, but all other lr models have one.
I've fitted the big rubber strips over all the areas, including where the rear door rubber thing shuts. that's why I had to buy 4, as I didn't want joins.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
The pitting shown in the 'after' picture is rust pitting, even if in there opinion they had rubbed it down suficiantly, they could not have removed the rust from these pits and it will always just be a matter of time before its back...
As ever, thanks for the helpful replies:
