Home > Maintenance & Mods (L322) > Rear Arches - How long before corrosion returns |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
I'd just bounce it back to the dealer and tell them to do it properly. Repair should be invisible once they've finished - and if there is rust they should cut out the rusty metal and weld a new piece in. |
24th Jan 2014 2:00pm |
Thanks... bit embarrassed to take it back after all the issues we had with the car to start with... it's still a warrantied repair right enough. Just wondered if others had it come back and it was something to 'keep an eye on but live with' Thanks |
24th Jan 2014 3:06pm |
I wouldn't be living with it I'm afraid. Either they do a proper job or they get it back. |
24th Jan 2014 3:07pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
You can stop the corrosion coming back thro from the rear by simply coating the rear surface of the arches with a liberal coating of general purpose grease.
24th Jan 2014 4:08pm |
Thanks Simes and NDF...
24th Jan 2014 4:52pm |
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 |
The dealer will get payment from landrover and it should be perfect. Complain take it back and tell them this it will be in there best interest to sort it out |
24th Jan 2014 8:28pm |
@pld 118
24th Jan 2014 9:03pm |
Great reply NDF, thanks very much.
24th Jan 2014 9:18pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
I had mine tidied up and then fitted the wheel arch protectors from other models, that we're never fitted to the L322.
25th Jan 2014 7:42am |
Thanks Mark,
25th Jan 2014 8:30am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8513 |
There isnt a strip fitted as standard, but all other lr models have one.
25th Jan 2014 8:58am |
I've fitted the big rubber strips over all the areas, including where the rear door rubber thing shuts. that's why I had to buy 4, as I didn't want joins.
25th Jan 2014 10:16am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
The pitting shown in the 'after' picture is rust pitting, even if in there opinion they had rubbed it down suficiantly, they could not have removed the rust from these pits and it will always just be a matter of time before its back...
25th Jan 2014 10:28am |
As ever, thanks for the helpful replies:
25th Jan 2014 12:26pm |
