Home > In Car Electronics (L322) > M.O.S.T loopback fibre cable for testing continuity
ppcsl
Scotland 2005 Range Rover Autobiography Td6 Java Black
Hi Can anyone tell me where I can get a fibre optic loopback cable to test my system for duff modules. I don't want to muck about taking the fibres out of the sockets if I can get one of these cables. Even if I can get the part number of the female socket I could probaably make one up. I work in IT and have hundreds of fibre patch cables lying about.
George Traded in my Audi TT 225 for my Range Rover TD6 Autobiography in Java Black. Range Rover now sold.
Post #236234 21st Jan 2014 10:52am
What module do you think is duff? I have a duff Nokia module and have been meaning to take the connector off and connect some of the fibre cable I have to make a loopback tester. Previously..
Post #236238 21st Jan 2014 11:03am
ppcsl
Initially thought it was the amp, so I bought one of bay. Tried it at the weekend still the same. I did notice the TMC module was shorting against anything metal when it touched so I am thinking it is goosed. There is a female connector in the bottom of the boot space but I didn't get the part number off it, I will try and get it at the weekend if no one can help on here.
I did follow the circuit round and it looked like there was no light coming from after the TMC module so again it would point to it being duff, but just wanted to get a loopback to test. Traded in my Audi TT 225 for my Range Rover TD6 Autobiography in Java Black. Range Rover now sold.
Post #236240 21st Jan 2014 11:16am
If you have a fibre cutter I would just be pushing a link of cable into the end of the connector just to prove if the system will fire up. As long as the faces are touching it will work for testing. Previously..
Post #236251 21st Jan 2014 11:53am
ppcsl
Thanks Contraband, I think I will just do that. I have a load of old ST, LC and SC cables that I can play about with to try and mock something up that can do the job. I was just being lazy Yawn
Post #236254 21st Jan 2014 12:08pm
ppcsl
Got the part number from the connector in the boot, I thought I should just get it and do a search on google to see if anybody sold it. The part number is tyco 1-1394916-1 and guess what can't find it anywhere. Land Rover must do a loopback for test purposes. Or do they just replace everything at the customers expense....yeah. Traded in my Audi TT 225 for my Range Rover TD6 Autobiography in Java Black. Range Rover now sold.
Post #236348 21st Jan 2014 8:11pm
You have a spare amp? Could you somehow plug that in in place of the TMC module to utilise its MOST port? Previously..
Post #236352 21st Jan 2014 8:36pm
ppcsl
Never though of that contraband good idea. I will try it at the weekend. Does the circuit not require to be amplified to travel through the loop?
Post #236379 21st Jan 2014 10:32pm
