Home > Technical (L322) > TDV8 Alternatorh how to change/replacement pics
Page 2 of 7 <1234567>
No, they tend to take a while... My best guess is thats the time the ECU's take to settle down... Thumbs Up
Post #235902 19th Jan 2014 4:49pm
T24RES
Oh OK, that's sort of good news. I'll try the test as you suggest, thanks for the quick update Bow down
I'll report back Thumbs Up
Post #235906 19th Jan 2014 4:52pm
T24RES
Having tested the car this morning as advised by Craig, without load a healthy 14.8v. Once loaded as described, the voltage drops to 11.73v Big Cry
I am assuming I need to replace the alternator as is struggling once loaded?
Cam-Tech-Craig wrote:
B, when your testing your alt output, 14.8v after 2mins... Leave the car running and then put on all the lights, the heated screens, the blowers etc etc etc which will really make your alt work hard and keep an eye on that reading... It will fluctuate slightly but should not drop much below 13.5v... Much under that and you have issues sir Bow down
Post #236244 21st Jan 2014 11:24am
T24RES
Part numbers should read YLE 500440 & YLE500340 , typo I expect.
northernmonkeyjones wrote:
There are 2 lr part codes depending in vin number....
Yle550440 8a268514 ->
Yle550340 7a000001 -> 8a268514
I'm wondering if they changed it....... Cos it was failing and they are the difference between the 6 ribbed belt and the 8 ribbed belt?
Conor are you after of before the vin changeover? I am after so mine is yle500440
Just a theory......
Post #236277 21st Jan 2014 2:38pm
T24RES
PM's sent
mike & the mechanics wrote:
14.8 is spot on, but maybe worth putting everything on electrical in the car & rechecking. It maybe that its breaking down under load. If you do change it & need any advice feel free to ask. It is a pig but not that complicated. Good luck Mike Thumbs Up
Post #236278 21st Jan 2014 2:48pm
Just checked mine using the inboard voltage readout, read 13.5 to 14.5 pretty much constantly however did drop down to 11.5 when I threw a load of gadgets at it..... But that was with both screens blowers lights and seats on?
Does that sound scoobied? There is nothing that can't be fixed with a hammer😜😜
Post #236345 21st Jan 2014 7:55pm
Googsy
I would just wait and see if it goes it goes. Any whinning noise when accelerating and decelerating? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #236347 21st Jan 2014 8:03pm
T24RES
Funny you should mention whining, I've got a bit if that going on. Is that a tell take sign?
Post #236353 21st Jan 2014 8:39pm
Googsy
Good yes impending doom imminent it's a tell tale sign happened me whined for about month and a half. Really noticeable when cold up to about. 2000 rpm then it's drowned out by engine but then it returns when decelerating. Mine then got worse and after a non start the following day the red battery light appeared so luckily had enough juice to get to garage. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #236360 21st Jan 2014 8:56pm
No whining yet. Pretty ok waiting for it to go but have got a few continental trips planned later in the year so will need to be done for then. There is nothing that can't be fixed with a hammer😜😜
Post #236376 21st Jan 2014 10:23pm
T24RES
Alternator is out, now where is the UPS man with the new one?
Post #236625 23rd Jan 2014 1:47pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
^ For your convenience he'll be there between 5am and 11pm Whistle 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #236627 23rd Jan 2014 2:09pm
T24RES
Probably -
Post #236629 23rd Jan 2014 2:21pm
Googsy
Did you take that out yourself? At least.once its done should last your length of ownership. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #236661 23rd Jan 2014 4:26pm
How was the surgery? Easy enuff? I am pretty handy with a set of spanners but the level of cant be bothered to do it if its going to hurt me is quite high!
I take it that that the latter vin needs the 8pk alternator pulley? Going to order one off ecp to have in when it goes and it can go to my local mechanic if its too hurty as he only charges £30/hr. There is nothing that can't be fixed with a hammer😜😜
Post #236676 23rd Jan 2014 5:43pm
