Home > Maintenance & Mods (L322) > Range Rover L322 - Stuck in Extended or Off Road Height
Page 1 of 5 12345>
I just thought I would share a small problem I had with my Range yesterday. It may be one for the WIKI.
With everything working fine and crawling along the M25 I suddenly got a bong and a Suspension Fault. Lights on centre console out and the warning not to exceed 30 mph.
On getting home I tested the suspension and found that it would not adjust but just kept bouncing up to the fully extended (super extended) height with the message: Please reset when object has been removed etc - it thought I was stuck on a rock or similar!
Using Hawkeye I was able to reset the suspension and clear faults but the same issue re-occured immediatly.
The fault explained that the System could not vent and thus was stuck in the highest setting with no way of going down.
With a bit of searching I founds that the Compressor has a brass coloured cone shaped exhaust muffler/filter (sintered brass filter) near the top at the front of the car end of the compressor (Take the black metal cover off with four bolts after removing spare tyre). Apparently this is gets blocked over time as it is a hard sponge type filter.
My dirty cone filter clogged with desiccant:
The fix is to remove this filter using a 13mm spanner (Its shaped into a nut head at the top) get back in the car and start up and then select normal suspension setting. The system will let out a gasp as the compressed air is released and the car will drop to normal. The code can now be cleared and all will be well.
The car can be used without the filter (bit noisier) but this is probably not sensible in the long term. Ideally a replacement needs to be sourced but I think these are only available as part of a service kit.
Another option is to drill a tiny hole through the cone filter through the middle to allow air to escape but very little chance of anything nasty getting in. The Cone filter can then be refitted and all is good.
Tiny hole drilled through from thread end of cone:
I believe there is a service kit with a new filter cone (sintered brass filter), but I strongly recommend also replacing the dryer at the same time, as its desiccant is what causes the muffler to clog in the first place. Thumbs Up
I think these "9mm Thread Sintered Brass Pneumatic Filter Noise Silencer Muffler" will fit: http://www.sourcingmap.com/pcs-9mm-thread-...tAodnDIAsw
http://www.amazon.co.uk/Thread-Sintered-Pn...B008ASX7P4
Last edited by Gazellio @ Prestige Cars on 16th Jan 2014 11:03am. Edited 9 times in total
Post #235223 16th Jan 2014 8:24am
Great little fix that Gaz, and easy enough for anyone to do.
Let's Wiki this Stan. Thumbs Up Discovery 4 HSE
Post #235225 16th Jan 2014 8:30am
Yes Adam really is a 15 minute fix that a Dealer would probably charge hours for (as they probably would not know what to do) and end up replacing all the height sensors first Laughing
Post #235226 16th Jan 2014 8:32am
its a known fault,
http://www.fullfatrr.com/forum/topic5724.h...air+filter
Post #235234 16th Jan 2014 8:58am
Yes Stan but that post is not exactly a WIKI fix is it.... Confused
Post #235238 16th Jan 2014 9:05am
Just need to know the thread size and one of these should work ok.
http://www.ebay.co.uk/sch/items/?_nkw=sint...4049132526
Post #235240 16th Jan 2014 9:17am
Yes I think the thread is 9mm I added this to the thread a little while back:
I have ordered from Amazon...
Post #235242 16th Jan 2014 9:24am
Never noticed your Edit Thumbs Up
I've also ordered some as definitely worth changing as a service item.
Post #235244 16th Jan 2014 9:34am
Yes my thoughts exactly even though the drilled one is working perfectly!
Post #235247 16th Jan 2014 9:49am
TugRR
Perhaps worth mentioning the model year / pump type, Gary - I understand there was a change at 06 MY ?
Good info !
Thumbs Up Where do you go after one of these . . . ?
Post #235257 16th Jan 2014 11:00am
Sorry yes this was 200MY Vogue SE Supercharged - I will add to post above Thumbs Up
Post #235259 16th Jan 2014 11:02am
jak480
Norway 2003 Range Rover Vogue Td6 Zambezi Silver
Hi
Just a tip you can buy these filters at any respectable pneumatic shop ( where they sell compressors,pneumatic valves,...) as they are very common used in pneumatic equipments
You can also clean them in petrol or with brake cleaner and then use a compressor to blow them dry.
Just a tip.
Post #235272 16th Jan 2014 12:09pm
^ Thumbs Up
Post #235280 16th Jan 2014 12:30pm
TugRR
. . . I'm going to check mine now you've mentioned it, Gary.
It looks like another item that should be on the service schedule . . . Rolling Eyes
Post #235290 16th Jan 2014 1:32pm
jak480
Something to think about Question As there is normally only "clean" air coming out of the system where is the dirt that bloks the filter coming from??
Could it be a indication for something else that is about to fail in the circuit ?
Or is it simply dirty air that is being sukt in ?
Just a thought.
Shocked Shocked Wink
Post #235296 16th Jan 2014 1:51pm
Page 1 of 5 12345>
