Home > Maintenance & Mods (L322) > Range Rover L322 - Stuck in Extended or Off Road Height |
I just thought I would share a small problem I had with my Range yesterday. It may be one for the WIKI.
16th Jan 2014 8:24am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
Great little fix that Gaz, and easy enough for anyone to do.
16th Jan 2014 8:30am |
Yes Adam really is a 15 minute fix that a Dealer would probably charge hours for (as they probably would not know what to do) and end up replacing all the height sensors first |
16th Jan 2014 8:32am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35264 |
its a known fault,
16th Jan 2014 8:58am |
Yes Stan but that post is not exactly a WIKI fix is it.... |
16th Jan 2014 9:05am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3971 |
Just need to know the thread size and one of these should work ok.
16th Jan 2014 9:17am |
Yes I think the thread is 9mm I added this to the thread a little while back:
I have ordered from Amazon... |
16th Jan 2014 9:24am |
Never noticed your Edit
16th Jan 2014 9:34am |
Yes my thoughts exactly even though the drilled one is working perfectly! |
16th Jan 2014 9:49am |
Sorry yes this was 200MY Vogue SE Supercharged - I will add to post above |
16th Jan 2014 11:02am |
jak480 Member Since: 06 Dec 2013 Location: Degernes Posts: 44 |
Hi
16th Jan 2014 12:09pm |
16th Jan 2014 12:30pm |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
. . . I'm going to check mine now you've mentioned it, Gary.
16th Jan 2014 1:32pm |
Something to think about As there is normally only "clean" air coming out of the system where is the dirt that bloks the filter coming from??
16th Jan 2014 1:51pm |
