Home > Technical (L322) > Parking heater
SATVC
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Parking heater
As the cold weather started I noticed the park heater would come on when the car was unlocked or if the door opened etc. During the summer this didn't come on at all! My question is does it do anything? Mine makes a roaring noise for a bit then turns off! I don't seem to have any heat from it in the cabin? Now we're getting the frosty mornings I'm waiting for the heated screen to clear the ice! Wasnt the webasto heater supposed to do this? If not what does it acctually do? Only it would be nice if mine working properly, only I have no clue what it does!
Thanks 2004 range rover vogue
Post #234766 14th Jan 2014 12:11pm
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
Mine comes on if I open a door or lock/unlock all through the year ... come rain or shine!
But I think that is just a pre-warming for the engine although I may be wrong. You need to activate the remote/times heating feature for the car internals to warm up. African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #234848 14th Jan 2014 4:39pm
SATVC
Ok thanks! If it's for engine preheating that makes sense! 2004 range rover vogue
Post #234849 14th Jan 2014 4:40pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
If the combustion fan operates when the car is unlocked or door opened (or bonnet) then the PCB is damaged
Mines the same - operates as above but FBH faults out and has yet to run properly - just waiting for some time off and good weather so I can do the PCB repair.
Post #234873 14th Jan 2014 7:03pm
SATVC
If that is the case Is it worth repairing? Car seems to run great even in this icy cold weather! If it doesn't warm the cabin etc doesnt have any real purpose IMO? 2004 range rover vogue
Post #234876 14th Jan 2014 7:07pm
Katash
If operating correctly, after a 30 min cycle you should have a pre-heated engine and cabin.
Post #234911 14th Jan 2014 7:41pm
SATVC
I don't notice any cabin heat so I presume something's wrong! It's defo not on for 30mins. Max of 5 mins then turns off! If engine doesn't start it turns on after unlocking or door opening then turns off after 1 min or so? 2004 range rover vogue
Post #234915 14th Jan 2014 7:45pm
Katash
As above - the behavior you are getting is typical of a PCB failure, same as mine
Post #234928 14th Jan 2014 8:20pm
SATVC
By PCB I presume you mean printed circuit board? Is the part of the heater or separate? Easy swap or whole unit? Thanks 2004 range rover vogue
Post #234931 14th Jan 2014 8:23pm
SATVC
They have a pre heater module Part no YWY000031 would this be the required part? 2004 range rover vogue
Post #234932 14th Jan 2014 8:26pm
Katash
Yes its part of the heater, easy to access and reasonably easy to repair (or there is a guy in France that will do it for you)
Post #234935 14th Jan 2014 8:28pm
SATVC
For me it's prob easier to change the whole heater then! I have a friend who breaks rr's I'll chat him up! Thanks for the advice, it's appreciated! Thumbs Up 2004 range rover vogue
Post #234936 14th Jan 2014 8:31pm
Katash
Easier yes but cheaper to fix existing one - pennies for the resistors or £45 for French Mike to do it for you
Post #234946 14th Jan 2014 8:50pm
DeRanged Rover
Can you still drive the car whilst the FBH is removed and away for repair? African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
Post #234982 14th Jan 2014 10:11pm
Katash
pretty sure you need to link the 2 water pipes with a piece of 22mm copper pipe and jubilee clips otherwise you may loose your coolant. Oh and blank the fuel pipe just incase
Post #234995 14th Jan 2014 10:34pm
