Home > In Car Electronics (L322) > New Owner Questions
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
New Owner Questions
I am picking up a 2006MY Vogue 4.4 V8 later this week and need to update the audio and phone.
The RR has the touch screen Sat Nav and TV but as this doesn't get a picture guess it is analogue only. There is an Old Nokia phone in a cradle in the centre console but does not appear to be connected (on test drive).
I would ideally like to be able to connect my iPhone 5S and other phones I use via Bluetooth for handsfree, not really fussed about streaming music from the phone. Am I better to try and get a new Bluetooth module or try a Parrott type system?
I would also like to be able to connect my ipod classic in to the stereo system to play tunes (I usually just have on random as over 15000 tunes but would ideally also like to be able to chose an artist, song, genre etc... if I want while on the move) I have Pure DAB radio (like the Alpine in some of the posts) which I have in my old vehicle but had to use an SOT lead when I connected that up but can't find what adaptor I need for the RR so any help would be appreciate if this is the best way to for the ipod to work.
What is the best (easiest) way to reinstate the digital TV (TV on the move not a major problem either way).
I live in Stevenage, Herts and work in Harlow, Essex so any suggestions on a company who could supply/install the above (ideally less than £1K) in my area (preferably at my office) would be appreciated.
Sorry first post is a question but could not find the introduction area.
Robert
Post #233239 6th Jan 2014 6:36pm
rej
Bump. Any suggestions, comments as various opinions in the various and I would like to try and get sorted asap.
Post #233467 7th Jan 2014 6:44pm
Hi... Have you tried the search function? Audio and Bluetooth are very common questions and all the answers are out there! Previously..
Post #233469 7th Jan 2014 6:47pm
as Archie has suggested , do a search and have a read ..
Post #233472 7th Jan 2014 7:04pm
rej
Thanks, I have had a look using search but various different answers and not sure which is which and current best suppliers etc... except for the Bluetooth exchange which looks like a member provides the service just need to check my module # when I collect.
Some posts say new tuner is plug and play other seem to suggest that new aerials and wiring are needed and other say coding is needed and just want the simplest solution simple DIY if possible.
Re my Pure DAB(similar the Alpine units referred to in various posts) which does the ipod, haven't seen anything yet about using SOT leads or aerial adaptors and really just wanted some info to avoid getting stuck with the dash apart only to find I need a part that I could have ordered in advance.
Post #233475 7th Jan 2014 7:29pm
Thumbs Up You seem up to speed....
I got my Bluetooth upgrade from Wiggs, but as you have found out he will only exchange from a certain serial number upwards... You will need to check first.
I think he also does the plug and play digital tv as well. I got mine on eBay, I was lucky as there are a few knocking about that don't seem to work. It really is just plug and play. You should be able to unplug the leads from the analogue unit, still in place, and test the new one... Before you pull it all to bits... Also, check for water ingress. Check the pins of the Bluetooth module for any signs of water damage. Search for water shedder.
No expert on the iPod integration, but search intravee, possibly for older FFRR, not so sure... Maybe some tips there.
Enjoy.
Thumbs Up Previously..
Post #233480 7th Jan 2014 7:56pm
rej
Is this the TV module I need to convert a 2006MY facelift to digital TV Model # AW93-14F641-BC PAGTVISDB
Post #233622 8th Jan 2014 7:00pm
rej
Sorry problem with the image. Does this unit need a viewing card of any kind?
Post #233623 8th Jan 2014 7:01pm
I searched "digital tv" and found this....
http://www.fullfatrr.com/forum/topic13683.html?highlight=tv+tuner
Your picture is of the type that will not work... Jap spec I believe... Previously..
Post #233626 8th Jan 2014 7:18pm
in all honesty i would spend the cash on a new tv for the house rather than a digital tuner for the FF..
you can only watch 'in car' when you have a decent signal and when the engine is running otherwise you'll get a flat battery...
Post #233628 8th Jan 2014 7:23pm
73vse
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Although, my wife and kids would say it's the best thing about my RR ( dual view)
Post #233630 8th Jan 2014 7:35pm
rej
So this would the right one?
Would probably only use while waiting outside kids dance and football lessons and if it works no too expensive compared with the dealer options I have been quoted and better than trying to watch on 3G/4G on the ipad. If just plug and play as suggested worth a couple of hundred £ plus I like to have everything working that should work.
Robert There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #233631 8th Jan 2014 7:36pm
Yip, the hybrid tuner....
I know what you mean, it would bug me having something like that not working, even if it it were not used all that often.
Ours was mainly used for dvd's, but if I needed the tv at least it worked. Thumbs Up Previously..
Post #233632 8th Jan 2014 7:40pm
As the guys have said its hit and miss in functionality at best, it needs a good signal and you cant watch it on the move as standard, though there is a tweek which can be done to enable tv on the move bit its illegal to have it on the front screen where the driver can see it.
In terms of the ipod, the best and pretty much only option if you want to have it connected into the system is the genuine lr kit, and the classic can then be kept in the dash. The trouble is that the search can be slow with a lot of tracks on the source, however if you keep it on random then it should be fine. Its pricey though at about 350.
A cheaper option is a splitter lead whch splits a 30 pin ipod cable to aux and usb, and a 12v to usb ciggy plug. That will work well if you have an aux socket and you can the keep the ipod in the centre console bit if you dont have an aux socket then the only other way is a transmitter.....
If that makes sense. There is nothing that can't be fixed with a hammer😜😜
Post #233634 8th Jan 2014 7:57pm
rej
Thanks, I don't have the Aux input anywhere (at least not visible). I have a PURE DAB (same as alpine unit) tuner which runs the iod in my Nissan Pathfiinder and works fine for me but as per my other post just looking for confirmation what other leads I need (if any) to connect to the Radio/Nav unit. There is a difference between knowing your sh!t and knowing you're sh!t
Post #233637 8th Jan 2014 8:25pm
