Home > Technical (L322) > EGR gunk
ocahan
Ireland
EGR gunk
Shocked decided to have a look at my egr valve today!
Is this excessive for a 04 FF 94k on the clock?
Have it all cleaned up but decided now to blank it off,just waiting on the kit to be delivered Thumbs Up
Do i have to clean out the manifold? undone all the bolts but its not moving Question didnt want to force it in case something snapped lol
Post #232456 2nd Jan 2014 10:16pm
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
Blimey that’s a fair bit of carbon build up...........i didn’t clean the manifold when i did mine but didn’t have quite the same build up as yours. I did clean the entry hole into the manifold being careful not to let any bits drop inside.
On mine i did a full clean of the standard egr and disconnected the vacuum hose and blocked the hose and the hose nipple with a small self tapping screw which works fine.
The egr blanking replacement will be as good if not slightly better as it has no vacuum valve inside............enjoy the upgrade
Post #232463 2nd Jan 2014 11:03pm
mine was bad but not as bad as yours..i just cleaned as much as i could see before the blanking..
Post #232503 3rd Jan 2014 9:55am
wealy
Wow - that is a bad one. I would run some fuel cleaner through the tank for a few fill - ups. I would also use Shell V power for a while (if you can get that in Ireland)
Post #232821 4th Jan 2014 2:35pm
Here's mine after circa 120k miles - 2003. No idea if it's original or been cleaned, but not during the 50k miles of my ownership.
It's been replaced with a blanking kit giving a 13% improvement in fuel consumption.
Post #233074 5th Jan 2014 6:04pm
