![]() | Home > Maintenance & Mods (L322) > Stiff steering ( again ) . New spin on old problem . |
coasterburner Member Since: 03 Jan 2014 Location: Crewe Posts: 13 ![]() ![]() ![]() |
Hi . My 2004 Vogue is unsteerable on tickover . It is overly stiff at 50 - 60 MPH on A roads . Call me old fashioned , but when I owned XJ6s in the early 1980s , the steering was featherlight at all speeds and you just got used to it . My P38 has no newfangled servotronic sh*te on it , but feels safe and solid at all speeds and in all conditions . My plan is to purchase a 12v to 9v reducer and plug it straight into the servotronic socket under the wheel arch . In theory , this should set the steering to the lighest setting at all times . Has anyone tried this already ? No amateur BS theories please . Realists only need reply .
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 ![]() ![]() |
well documented here
All that gets me is hundreds of pages of assorted rubbish with no thread ???????????? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34982 ![]() ![]() |
i cant see you getting much help with that attitude |
No attitude intended . Meant as a question . |
Been told today I'm being made redundant next Saturday . Perhaps a tad too bladdered to be posting . Sorry guys . |
ok than
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 ![]() ![]() ![]() |
Mine was stiff when standing and ok on the move, i found the lower steering joint the problem a good few goes with wd40 and it got better then i put some light oil on steering a lot lighter now when standing on tickover. Also check your tyre pressure if they are low you will get stiffer steering at tickover.
BCU & Servertronic valve are both under £100. |
Thanks for the good advice . Will lube the joint when (if) the rain stops . Also , £100 seems very cheap for a BCU ? |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 ![]() ![]() ![]() |
still heavy steering....this might sound weird, but I had a good car till I fitted a dashcam, and used a piggyback fuse on I think fuse 41 in the glovebox. which I think said it was for the rain sensor. as I piggybacked it, sensor should still work. however on driving it, my steering was quite heavy, to the point I thought I had no fluid. (dashcam working etc) I did some initial power steering checks, and figured if I take out that piggyback fuse it might cure it, and it did. nothing in fusebox says it was connected to my steering system, but somehow it was.
maybe the servotronic valve is wired to that fuse John.. ... - .- -.
I saw that the servotronic is labelled as a different fuse number, but it certainly affected the steering, I didn't notice it immediately, and didn't link the two together as it was a different day when I drove it.
do you mean my dashcam?...if so ,i have it plugged in on my rse unit.. ... - .- -.
