Home > Technical (L322) > Water in fuel |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16268 |
As its such a new vehicle and obviously still under warranty, i would get it checked by your main dealer pal... Ordinarily it would point to a poorly serviced older vehicle (not having had the fuel filter changed in years & years but is obviously not the case with yours sir... |
4th Jan 2014 12:47pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 797 |
thanks Craig - it is having a service in a couple of weeks.
4th Jan 2014 12:57pm |
I would ask them to check if the fuel filter is due changing?
4th Jan 2014 1:13pm |
jak480 Member Since: 06 Dec 2013 Location: Degernes Posts: 44 |
Hi
4th Jan 2014 2:16pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
The fuel filter (and ts electrical connection) are in the engine bay and way out of harmful waters way. (Unless you were wading over the bonnet) so I doubt it was a fault, The tank and all the lines are sealed and would not get water ingress unless you have a leak which would be obvious. Craigs suggestion of the water in cheap or supermarket fuel is probably the correct reason and just a coincidence after you went through the puddle.
4th Jan 2014 2:31pm |
Wealy
4th Jan 2014 2:38pm |
never use supermarket diesel - only BP Ultimate or Shell V-Power.
4th Jan 2014 5:34pm |
4th Jan 2014 5:36pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35249 |
its probably something simple as condensation in the tank or filter.... |
4th Jan 2014 5:37pm |
Rambles
4th Jan 2014 5:42pm |
aus10RRW Member Since: 14 Aug 2013 Location: Aberdeenshire Posts: 16 |
I had the same issue on my 2012 Westminster. Started up the car one morning and headed into the villiage, halfway there the warning "WATER IN FUEL" popped up on the dash. The engine was running fine.
17th Jan 2014 1:42am |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 922 |
I had this last year. Same engine and MY. I called LR Assist as there is nothing in the handbook! They said I needed to have the fuel tank drained because it was dodgy fuel if it came up again. But it didn't. It also came up after going through water as you describe. Sounds like a dodgy sensor to me. |
17th Jan 2014 9:13pm |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 |
A mate has a 2007 tdv8, just had the water in fuel message
24th Feb 2014 8:48pm |
NailedOn Member Since: 09 Feb 2022 Location: County Durham Posts: 6 |
I had this message pop up today. I had just driven (slowly) through a large puddle. After a minute, it went out on its own. Can you point me to the rubber seal please. L322 Westminster 4.4 Diesel, 2012. Cheers. My Land Rovers, so far: Defender 90 V8 County Disco V8S Disco V8 GS Freelander 1 TD4 Freelander 1 V6 RR L322 Westminster |
15th Jan 2023 12:59pm |
