Home > Maintenance & Mods (L322) > Creak when parking RR?
pld118
Hi,
When stopping the SC, engaging P, activating the park brake on an incline and then releasing the footbrake when getting out of the car it makes quite loud squeaky creak (we had a Disco3 that did that from almost new as well). Any ideas please?
Thanks
Post #229618 16th Dec 2013 6:40pm
I am guessing it is just the parking brake taking up the strain. My TD6 doesn't squeak, but you feel the drums coming on line so to speak. Try applying handbrake, go to Nuetral, take foot off brake in Neutral, let handbrake take the weight, then footbrake back on to go into Park. This is the "approved" method (awaits Evil or Very Mad with interest Laughing ) .
Post #229627 16th Dec 2013 7:45pm
TugRR
^ I'm with you - brakes on first before engaging park . . .
Thumbs Up Where do you go after one of these . . . ?
Post #229661 16th Dec 2013 9:50pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
There's a 'roll' moving into park as the pawl grabs - it's not a huge amount in the gearbox but as it gets to the driveline it is exaggerated. Nearly all automatic gearboxes do this. So either put it in park, foot off brake, let it 'roll' then handbrake to lock, or expect physics to occur Smile Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #229663 16th Dec 2013 9:56pm
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Hmm, mine's never made a creaking sound though I just put my foot on the brake and press the start/stop button and the car puts it into park and applies the parking brake. I'm assuming it knows what it is doing. 4.4 TDV8 Vogue Baltic Blue MY11
Post #229672 16th Dec 2013 10:24pm
pld118
Never knew any of that (knew nothing was wrong with the car. I just put it down to, as you say, physics. Will try your suggestions and report back).
Thanks all. Very helpful Thumbs Up
Post #229711 17th Dec 2013 6:43am
Another vote for a variation of the above method.
I do footbrake, Neutral, apply e-brake, release footbrake to allow for any movement if on a slope, re-apply footbrake, Park.
Clearly, I don't do this all the time. At work on a completely level carpark, I just go straight into Park with no e-brake. Si. <This is my name.
Post #229712 17th Dec 2013 6:48am
pld118
Top tip gents thanks. The first descibed method tried and works a treat. The noise has 'gone'.
All those years of driving automatics without a clue about the 'correct way to park'... Wink
Thank you Thumbs Up
Post #229747 17th Dec 2013 12:26pm
i reckon its your old bones creaking Ryan.. Laughing ... - .- -.
Post #229752 17th Dec 2013 12:49pm
pld118
Do you know Stan, was going to put that on my reply in light hearted jest... but it would not have been true! Wink
Post #229754 17th Dec 2013 12:51pm
