Home > Technical (L322) > Wind Noise Drivers Side 50mph +
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi all
My 2010 MY S/C AB has noticeable wind noise from the drivers side A pillar when I get to around 50mph, the inner seal on the body looks ok condition wise as does the seal on the door, is it more likely that the external trim is the culprit?
A 2003 Vogue I owned a few years ago had something similar and the dealer removed the external trim and fitted new rivets / plugs to tighten up the seal between glass and trim but that doesn't look too bad, all rivets look tight although there is a slight gap between screen and the seal under the trim?
Sorry if similar posts have been made before, I wanted to ask based on my issue specifically.
Thanks
Carl
Post #226363 1st Dec 2013 4:14pm
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
had a similar issue in october .
the A pillar cover was loose. the rivets were ok on the door seal side .
the A pillar cover needed a firm push top middle and bottom and it clicked back in. 2011 4.4 TdV8 Nara Bronze
Post #226612 2nd Dec 2013 10:11pm
Dolphinboy
Can also be the rubber strip in the rain channel. Mine came away at the front and was like a ski tip at speed so caused a drone noise. Fixed it down and no more noise! Thumbs Up
Post #226622 2nd Dec 2013 11:12pm
carlos50
@ goldsax, will give the pillar trim a good press to see if its that.
@ Dolphinboy, how did you fix the seal underneath? Do you mean the one that makes contact with the screen?
Post #226687 3rd Dec 2013 1:07pm
Dolphinboy
Sorry wasn't clear! Can't take pictures as it was my prevIous rr and my present one has roof rails so it can't be seen.
The rain channel on the roof above the drivers door/side, running front to back. There is a rubber strip. You should be able to see it if it is sitting proud. Stuck it down with rubber glue/ bostik type.
Post #226688 3rd Dec 2013 1:13pm
pld118
Re: Wind Noise Drivers Side 50mph +
Where about on the A pillar is the noise coming from/ does is sound like a window is partially open?
Ours had this issue after a brand new door was fitted this year and the noise was directly in line with the driver's side outer mirror casing.
Intrusive Wind Noise - Manifested from 38mph and sounded like the driver's window was just open at the top although the window was fully closed. It transpired that when the wing mirror housing had been put back on the new door, the wing mirror housing/ a seal aligment were slightly out. There is apparently a Land Rover Technical Bulletin that main dealers have about the issue that affected ours which has since been remedied.
Post #226701 3rd Dec 2013 3:07pm
carlos50
It sounds like it comes from the front corner, there's no draft between door and A pillar from inside the car so perhaps it a whistle from air getting under the A pillar trim and not being able to go anywhere?
I need to have a look at the weekend
Post #226796 3rd Dec 2013 10:01pm
pld118
There was no draft with ours.
Post #227036 4th Dec 2013 8:47pm
