Home > Technical (L322) > Wind Noise Drivers Side 50mph + |
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 |
had a similar issue in october .
2nd Dec 2013 10:11pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3130 |
Can also be the rubber strip in the rain channel. Mine came away at the front and was like a ski tip at speed so caused a drone noise. Fixed it down and no more noise! |
2nd Dec 2013 11:12pm |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 |
@ goldsax, will give the pillar trim a good press to see if its that.
3rd Dec 2013 1:07pm |
Sorry wasn't clear! Can't take pictures as it was my prevIous rr and my present one has roof rails so it can't be seen.
3rd Dec 2013 1:13pm |
Where about on the A pillar is the noise coming from/ does is sound like a window is partially open?
3rd Dec 2013 3:07pm |
It sounds like it comes from the front corner, there's no draft between door and A pillar from inside the car so perhaps it a whistle from air getting under the A pillar trim and not being able to go anywhere?
3rd Dec 2013 10:01pm |
There was no draft with ours. |
4th Dec 2013 8:47pm |
