Home > Camping, Caravanning and Holidays > Just a quick tip for the Chunnel. |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 |
For ferry, when I have used the tunnel always had a delay so took as long as the ferry which is cheaper, even better value if you book via caravan club even if not towing and at least you can have a good break and leg stretch. Agree tunnel looking shabby.
20th Nov 2013 1:38pm |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
We used the Chunnel for the first time on Sunday after driving back from Germany with my new 22 year old motorhome.
20th Nov 2013 6:13pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8671 |
If you have booked high, you get a slightly different hanger with an up chevron over the car pictogram, and select the over 1.95m lane as you approach the queuing area, they check you have the correct ticket as you pass the little portacabin usually. This is all after customs etc. pretty self explaitory when you get there. There is nothing that can't be fixed with a hammer😜😜
25th Nov 2013 5:25pm |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
I've done it both ways . In the regular carriage it is tight but lock in access height and all is well. Remember to do this at the height check barrier on the approach or it it will catch the gps antenna. I know cos i did. Going in the regular height carriage gives more options for alternative trains, early or later arrivals etc.. The double height carriage is however less claustrophobic. Either way it works. 2012 5.0L S/C
25th Nov 2013 6:19pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2942 |
I've changed my access height to -60mm using IID tool so we should be ok. Looks nice when parked up in access mode too! |
28th Dec 2013 12:05pm |
