Home > Maintenance & Mods (L322) > Towing socket charger adapter - Any Experience ?
Page 2 of 3 <123>
Les Pes
Guernsey
Plugs into accessory plug that comes as standard on the c trek chargers
Good piece of kit Looking right now for the FFRR ultimate upgrade
Post #223284 15th Nov 2013 11:45pm
wealy
Is it the same connection as an optimate?
If so where can I get one?
Post #223287 15th Nov 2013 11:58pm
I made one up (just for the hell of it) with croc clips at the end, mated with a Ctek MXS7. Works a treat.
Still trying to figure out a good location to store it "outside the car", easily accessible in the event of a flat battery away from home.... .
Post #223306 16th Nov 2013 2:26am
keep it in your handbag Tim.. Mr. Green ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #223334 16th Nov 2013 11:17am
TugRR
Just realised I bought one of the Lidl chargers for my Caterham last winter - I wonder if that is compatible with one of Martin's adaptors . . . . ?
Thumbs Up Where do you go after one of these . . . ?
Post #223374 16th Nov 2013 6:11pm
I've got a couple of the Lidl chargers as well but they are unfortunately not compatible with Martins adapters.
No reason why you couldn't buy a 12S plug and make your own adapter up though. Thumbs Up
Post #223386 16th Nov 2013 7:14pm
Correction, there is a way to do it if you are prepared to cut the battery terminal clips off the Lidl charger.
ie cut the battery terminal clips off the Lidl charger, purchase one of the Ctek leads below, cut off the cigar socket, join the cut cables on the charger to the cut cables on the Ctek lead.
You then have a lead from the Lidl charger with a male Ctek plug which will then connect into the female Ctek socket on Martins adapter.
You could connect the cables together a number of ways.
You could even buy another Ctek cable with battery clips on so that you could also connect your Lidl battery charger to the battery terminals as original.
http://www.ebay.co.uk/itm/CTEK-Comfort-Con...4abc8e6d25
Post #223393 16th Nov 2013 8:04pm
TugRR
^ Thanks for that - I'm not sure of the output of the Lidl charger ? - I'll have to dig it out of the garage
Post #223397 16th Nov 2013 8:38pm
The instruction manual states it is suitable for batteries upto 120Ah.
It gives out 3.8A at 14.7V which is adequate for the 110Ah battery in the FFRR, it just takes a bit longer to fully charge.
Good chargers, never had any bother with them.
Post #223401 16th Nov 2013 9:02pm
silversurfer
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Orkney Grey
So in the event that you find yourself locked out and unable to open the vehicle (flat battery) is it possible to connect up a battery to the tow bar socket and open the vehicle.?
http://www.fullfatrr.com/forum/images/smiles/icon_idea.gif
I ask this as I cannot leave the battery on charge using the socket due to the vehicle being parked outside.
Just a thought as you would then have access to the vehicle etc. etc.
Post #223499 17th Nov 2013 2:37pm
Yes - you can wire up a battery to the tow socket & then open the doors.
Obviously, the cabling is too thin to try starting the car, but at least it will let you unlock the cat to open the bonnet.
Post #223537 17th Nov 2013 6:25pm
Martin
Site Admin
Yes I do an Optimate version (for either type of connector) - www.fullfatrr.com/shop
Post #223618 18th Nov 2013 10:09am
Martin
Site Admin
The Lidl charger would require a connector of some sort adding to the leads as they have only ring terminals on the end which go straight to the croc clips.
If you just want a CTEK plug this is a cheaper way to get one: http://www.amazon.co.uk/C-Tek-Comfort-Conn...00ADIHUUW/ (unless you have a use for the cigar socket)
Or if you don't need CTEK compatibility (I do the adapter with other connectors) then perhaps use these: http://www.ebay.co.uk/itm/190908532647 which are the older style Optimate connector. Cut the Lidl charger's lead about 20cm back from the croc clips and you then have a charger you can use with Optimate accessories.
I've actually got a couple of pairs of these connectors if necessary Whistle
Post #223620 18th Nov 2013 10:22am
drivesafe
Australia 2007 Range Rover Vogue TDV8 Stornoway Grey
Hi Martin and can I make a suggestion.
Have you made up any of your plugs using Anderson 30 amp Power Poles.
These are very small ( as compared to 50 amp Anderson plugs ) but could be used to mate with any non standard chargers. 2007 TDV8 Lux
Post #223622 18th Nov 2013 10:29am
Martin
Site Admin
I haven't but then I've never been asked for one Wink
The issue would be that the permanent 12V to tow electric sockets is rated at 15A, so I would not be keen on supplying an adapter which would permit use of higher current chargers.
Post #223623 18th Nov 2013 10:32am
Page 2 of 3 <123>
