Home > Maintenance & Mods (L322) > Towing socket charger adapter - Any Experience ? |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Is it the same connection as an optimate?
15th Nov 2013 11:58pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
I made one up (just for the hell of it) with croc clips at the end, mated with a Ctek MXS7. Works a treat.
16th Nov 2013 2:26am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35117 |
keep it in your handbag Tim.. ... - .- -.
16th Nov 2013 11:17am |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
Just realised I bought one of the Lidl chargers for my Caterham last winter - I wonder if that is compatible with one of Martin's adaptors . . . . ?
16th Nov 2013 6:11pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3964 |
I've got a couple of the Lidl chargers as well but they are unfortunately not compatible with Martins adapters.
16th Nov 2013 7:14pm |
Correction, there is a way to do it if you are prepared to cut the battery terminal clips off the Lidl charger.
16th Nov 2013 8:04pm |
^ Thanks for that - I'm not sure of the output of the Lidl charger ? - I'll have to dig it out of the garage
16th Nov 2013 8:38pm |
The instruction manual states it is suitable for batteries upto 120Ah.
16th Nov 2013 9:02pm |
silversurfer Member Since: 24 Oct 2013 Location: londinium Posts: 84 |
So in the event that you find yourself locked out and unable to open the vehicle (flat battery) is it possible to connect up a battery to the tow bar socket and open the vehicle.?
17th Nov 2013 2:37pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7898 |
Yes - you can wire up a battery to the tow socket & then open the doors.
17th Nov 2013 6:25pm |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
Yes I do an Optimate version (for either type of connector) - www.fullfatrr.com/shop |
18th Nov 2013 10:09am |
The Lidl charger would require a connector of some sort adding to the leads as they have only ring terminals on the end which go straight to the croc clips.
18th Nov 2013 10:22am |
drivesafe Member Since: 19 Mar 2008 Location: Gold Coast Posts: 126 |
Hi Martin and can I make a suggestion.
18th Nov 2013 10:29am |
I haven't but then I've never been asked for one
18th Nov 2013 10:32am |
