Home > Technical (L322) > Swan neck
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
Swan neck
Hi everyone,
I have a quick tow bar type question. I have bought all the bits for a tow bar; the armiture is fitted and I have got a receiver and a swan neck. The swan neck is type one with a red key on it, what I can't work out is how the swan neck goes into the receiver ?
The key when in the two positions seem to allow a dial to be pulled out slightly and turned.
Any help greatly appreciated!
Andy
Post #223446 17th Nov 2013 8:04am
You need to pull the handle out and turn it until it locks before pushing into the hole.Then when you push it into the reciever it will self engage.
To remove. Pull out handle/knob turn until it locks and it should come out. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #223448 17th Nov 2013 8:16am
andyleeds
cheers i will have a crack this afternoon, also i am assuming that there should be some sort of pin to keep the receiver from falling out of the armature?
andy
Post #223480 17th Nov 2013 11:27am
A bolt with an anti vibration nut and a security pin/circlip (as it tends to constantly vibrate loose when towing weight)
Post #223484 17th Nov 2013 11:41am
Like that There is nothing that can't be fixed with a hammer😜😜
Post #223487 17th Nov 2013 11:52am
Thumbs Up Bow down Thumbs Up
Post #223492 17th Nov 2013 12:09pm
andyleeds
excellent, where would i purchase such an item?
Post #223503 17th Nov 2013 1:52pm
Dan Whistle Thumbs Up
Post #223504 17th Nov 2013 1:57pm
andyleeds
cheers craig, will ping him a line.....
also am after a couple of piano black interior parts.... have you got any in your "Aladdin's cave" ?
andy
Post #223508 17th Nov 2013 2:23pm
Which ones fella?
Post #223509 17th Nov 2013 2:25pm
andyleeds
am after the bits that go either side of the satnav screen do you have any?
andy
Post #223519 17th Nov 2013 3:17pm
I'll look tomorrow...
Post #223522 17th Nov 2013 3:52pm
andyleeds
cheers mate
Post #223526 17th Nov 2013 4:34pm
