Home > Technical (L322) > Swan neck |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8512 |
You need to pull the handle out and turn it until it locks before pushing into the hole.Then when you push it into the reciever it will self engage.
17th Nov 2013 8:16am |
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 952 |
cheers i will have a crack this afternoon, also i am assuming that there should be some sort of pin to keep the receiver from falling out of the armature?
17th Nov 2013 11:27am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
A bolt with an anti vibration nut and a security pin/circlip (as it tends to constantly vibrate loose when towing weight) |
17th Nov 2013 11:41am |
17th Nov 2013 11:52am |
17th Nov 2013 12:09pm |
excellent, where would i purchase such an item? |
17th Nov 2013 1:52pm |
Dan |
17th Nov 2013 1:57pm |
cheers craig, will ping him a line.....
17th Nov 2013 2:23pm |
Which ones fella? |
17th Nov 2013 2:25pm |
am after the bits that go either side of the satnav screen do you have any?
17th Nov 2013 3:17pm |
I'll look tomorrow... |
17th Nov 2013 3:52pm |
cheers mate |
17th Nov 2013 4:34pm |
