Home > Technical (L322) > Revs rising to 3000 rpm when climbing a small hill
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
OK, last week my wife was driving our L322 (2003 4.4 Petrol) into Salisbury from Devizes. Through one of the villages (Shrewton) there is a slight hill as you are coming out of the village. Normally the car drops down a gear with a bit of throttle applied to keep to the 30mph speed limit.
On this instance though, she said the gearbox dropped down a gear, but then the revs started to increase to 3000 where they stayed at 3000 until she was forced to pull over and switch off the ignition. On restarting the car all was OK and its been OK over the weekend.
Any ideas? Sticky throttle? if so, where to dose it with WD40?
(There are no errors showing and the gearbox / TC was completely rebuild 2 years ago, car has done approximately 8000 miles since rebuild. Mileage now is just over 100K)
Post #222384 12th Nov 2013 1:52pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
I had similar intermittent problem on another car I used to own - revs would climb to 3,000ish rpm and sit there
(was very embarrassing when stopped at traffic lights!)
Turned out to be a loose connection to the throttle position sensor. I wrapped some electrical tape around the male connector to make the fit tighter and it never did it again 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #222385 12th Nov 2013 2:00pm
PaulTyrer
Where is this throttle position sensor located?
Post #222386 12th Nov 2013 2:01pm
GraemeC
Unfortunately, I've no idea where it is on a Range Rover - I'm sure someone more knowledgeable will be along soon to help! 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #222387 12th Nov 2013 2:24pm
