![]() | Home > Maintenance & Mods (L322) > Rear track rod bolt seized advice please sorted. |
Just when I thought I would have my car sorted it appears bolt on rear track rod at chassis end is seized. Now the toe is out on drivers rear side. I thought all adjustment was done mid track arm. Anyway they showed me that despite turning the nut it only turned the bush at chassis . I even got to use my iid tool to put car into TTM |
Advanced Factors Site Sponsor Member Since: 31 May 2013 Location: Southampton Posts: 198 ![]() ![]() |
5C486 Is the part we discussed - adjustable on the bolt Paul Redding +44 (0)23 8052 2760 paul@advancedfactors.co.uk ![]() ![]() |
I need track rod tie rod that looks like droplink. I'm confused as did not believe nut at chassis end offered adjustment. See pic below might help.
Droplink (on ends of ARB) is a stabiliser link, not adjustable
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
That is indeed a rear toe link (Panhard rod) for a sport, on my way to work in a mo to open up for a RRS user who is urgent for some bits, will try to find the number when I get there unless anyone comes up with it first |
just had a look and mine has a toe rod like in the pic i posted, can't see anything which looks like your pic |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Googsy
IMSC @ �25 each side, suggest you replace in pairs, then get tracking sorted .
gen about �50, aftermarket from 20 a side.
