Home > Maintenance & Mods (L322) > Rear track rod bolt seized advice please sorted.
Page 1 of 3 123>
Googsy
Just when I thought I would have my car sorted it appears bolt on rear track rod at chassis end is seized. Now the toe is out on drivers rear side. I thought all adjustment was done mid track arm. Anyway they showed me that despite turning the nut it only turned the bush at chassis . I even got to use my iid tool to put car into TTM Cool Anyone know what part it is as in number I think I need to replace whole rear track rod and bolt. Is it an easy job to do ? Thanks.
Conor Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #221856 9th Nov 2013 4:47pm
Advanced Factors
Site Sponsor
5C486 Is the part we discussed - adjustable on the bolt Paul Redding
+44 (0)23 8052 2760
paul@advancedfactors.co.uk
Post #221858 9th Nov 2013 5:08pm
RGD500180 is the toe link at the rear, I think, though it doesn't look adjustable.......
thats the one referenced in the above post Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #221859 9th Nov 2013 5:14pm
Googsy
I need track rod tie rod that looks like droplink. I'm confused as did not believe nut at chassis end offered adjustment. See pic below might help.
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #221860 9th Nov 2013 5:16pm
Advanced Factors
Site Sponsor
Droplink (on ends of ARB) is a stabiliser link, not adjustable
The other one has an offset fixed washer on the bolt to adjust angle Paul Redding
+44 (0)23 8052 2760
Post #221861 9th Nov 2013 5:18pm
not that one then.... There is nothing that can't be fixed with a hammer😜😜
Post #221862 9th Nov 2013 5:21pm
Googsy
Big Cry Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #221863 9th Nov 2013 5:23pm
Advanced Factors
Site Sponsor
That is indeed a rear toe link (Panhard rod) for a sport, on my way to work in a mo to open up for a RRS user who is urgent for some bits, will try to find the number when I get there unless anyone comes up with it first Thumbs Up Paul Redding
+44 (0)23 8052 2760
Post #221864 9th Nov 2013 5:26pm
just had a look and mine has a toe rod like in the pic i posted, can't see anything which looks like your pic Question and it is the only thing which controls the toe at the rear there is nothing else connected to the hub bar the wishbones and the d/s.
in which case the parts boringoldgit and i suggest are the ones.RGD500180 There is nothing that can't be fixed with a hammer😜😜
Post #221865 9th Nov 2013 5:26pm
Googsy
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #221866 9th Nov 2013 5:27pm
Googsy
The last picture by northenmonkeyjones (not that one then) is the item that you use to adjust the rear toe in/out with. The 07-10 workshop manual makes no mention of another adjuster rod as in your picture ?
By the sound of it the bolt is just going round, didn't "they" hold the bolt when they tried to turn the nut?
If the whole bush is going round this may be the reason your toe is out?
Getting the inner off is fairly straight forward but a fiddle to get at. The problem you are likely to have is removing the nut of the tapered end at the hub, unless LR improved the design over earlier models.
When changing mine i couldn't get anything on it to turn it so ended up using a hacksaw and grinder across the nut to remove it. You can only damage the parts you are going to replace doing this.
Check out my rear suspension howto in the wiki .
Post #221867 9th Nov 2013 5:31pm
conor this is the drop link, RGD000131
the toe can only be adjusted by moving the orientation of the hub and as such whatever adjusts it must be attached to the hub. there is nothing else attached, hence must be that part. Thumbs Up (not the arb drop link pictured in this post thats something different altogether) There is nothing that can't be fixed with a hammer😜😜
Post #221868 9th Nov 2013 5:32pm
Googsy
Big Cry I haven't a clue...... You are right northern
Thanks guys so you are right. I have no issue getting it cut out and replaced. Any idea of cost of part?
So are both ends adjustable ? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #221870 9th Nov 2013 5:34pm
IMSC @ �25 each side, suggest you replace in pairs, then get tracking sorted .
Post #221871 9th Nov 2013 5:35pm
gen about �50, aftermarket from 20 a side.
only inner end is adjustable using an eccentric fitting by the look of it, the outer end is a ball joint and fixed.
if you look closely at Microcat you can see that the fixing bolt has off centre washer attached to the head end which will move the toe rod in and out slightly
as such you may only need the bolt! There is nothing that can't be fixed with a hammer😜😜
Last edited by northernmonkeyjones on 9th Nov 2013 5:40pm. Edited 3 times in total
Post #221872 9th Nov 2013 5:36pm
Page 1 of 3 123>
