![]() | Home > Maintenance & Mods (L322) > Rear track rod bolt seized advice please sorted. |
Cheers Joe are both end required for adjustment during alignment?
You are probably spot on might just replace the lot to be certain. I wonder if it's possible to un seize bolt might get some wd40 on it and get to my mechanic on monday. Hopefully Steve can sort the bits . |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Thanks for your help guys it's not the end of the world as long as I get it done soon.
Out of interest has this ever happened anyone else just wondering if they are prone to wear and therefore lose ability to retain arm in correct position?
Probably something which doesnt get looked at all too often as i would bet 90% of owners are unaware of the ability to do a 4 wheel alignment. There is nothing that can't be fixed with a hammer😜😜
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Yes I've had mine done, they need to be adjusted when you change the rose bushes |
47 meaning the bush / bolt at chassis end does wear and causes bush to spin when tightened? thanks |
Could be just one of those things Googsy, seems odd that on your '08 the bush has "gone" whereas on my '02 they were still in pretty good nick when I replaced them (madly chose to replace all bushes at rear in one go!)
As you pointed out I'm sure they must have held one bolt whilst trying to turn the other. I think he said nut wouldn't move any further when tightening so when he let go it moved back into original spot it could be the the thread on the bolt that could be damaged. It's amazing that I have had 3 alignments recently from different garages yet they never commented that's what has me baffled .Going to my mechanic Monday as he can put it up on the ramp for a look.Thanks for your help |
If the bolt is still free to turn when you tighten the nut to lock the eccentric bolt in position would it not be possible to place a washer or two under the nut so that it can then be tightened correctly? |
Not sure what you're saying...
But if the bush actually is going round and round there is a problem .
What does an eccentric bolt look like sorry for all the questions but trying to educate myself |
