Home > In Car Electronics (L322) > Digital TV Upgrade
Page 7 of 18 <123 ... 678 ... 161718>
peter6uk
United Kingdom 2005 Range Rover Vogue Td6 Stornoway Grey
Hi Wiggs, good to hear. Do they work with the standard aerial or will that need an upgrade. That said my current picture is shocking at present which i suspect is the aerial so was going to try and fix that first but having fun trying to work out how it's connected.
Post #22149 12th Jul 2010 1:27pm
wiggs
There are actually 4 arials ..2 on each side rear windows ..connected to antenna amps .
These dont need changing for the digital tv ..they are in the same frequency band
Post #22151 12th Jul 2010 1:32pm
BobbyDazzler007
2008 Range Rover Vogue SE TDV8 Buckingham Blue
Hi Wiggs
Have a MY2008 RR with rear screens, I'm assuming that the swapping over the tuners will work for me?
I've sent you a PM, keen to buy one.
Thanks
Post #22489 16th Jul 2010 12:15pm
Chemgopete
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
Hi Wiggs
I have a 2006 face lift RR with touch screen analogue tv, no rear screens interested in buying a digital tuner.
Have you any left. I've sent you a PM look forward to hearing from you.
Thanks
Post #22644 18th Jul 2010 2:56pm
Chemgopete
Hi Wiggs
Received next day, unplugged the old analogue tuner plugged in the digital tuner switched on less than five minuets after starting task hey presto digital and analogue stations works great. Thanks a lot for the speed of delivery. Just need tv in motion now.
Post #22912 21st Jul 2010 9:56pm
wiggs
No problem Thumbs Up
Picture should be better than old analogue aswell. Very Happy
Get yourself one of these http://cgi.ebay.co.uk/TV-Free-Video-Motion...3caf3c00c8
Picture in motion ...very easy to fit ..plug and play .. Thumbs Up
Post #22913 21st Jul 2010 10:12pm
wiggs
I have a few more tv tuners here if any one is still after one
Post #28252 16th Sep 2010 11:56pm
Bigbangman
United Kingdom 2006 Range Rover Vogue SE TDV8 Java Black
Question Question Question
Hi, when these "TV in motion" things say plug and play into the head unit, does this mean the back of the display or somewhere in the left of the boot.
My guess is its the back of the display which mean taking the thing apart somehow? Am i right cos it puts me off a bit knowing how i tend to break things i take apart!!!
Regards If its not broke now it soon will !!!
Post #28384 18th Sep 2010 1:05pm
wiggs
Not sure on the FFRR Embarassed
I have a discovery 3 and it was just a case of unplugging the lead to the radio and connecting in the little box
Post #28401 18th Sep 2010 4:13pm
Regards
your correct .the dash has to be taken apart to get access to the rear of of the screen ,then it is 'plug and play'.. ... - .- -.
Post #28412 18th Sep 2010 6:05pm
simonmanx
Isle Of Man 2005 Range Rover Vogue SE Td6 Java Black
hi wiggs what the price of thr units
Post #28414 18th Sep 2010 6:15pm
wiggs
�300 + �8 next day delivery
Post #31381 11th Oct 2010 11:46am
Hackweg
England 2005 Range Rover Vogue Td6 Java Black
Once fitted is there anything else you need to do to get the Digital TV working ? with a D4 TV Box?
Post #31551 12th Oct 2010 6:46pm
wiggs
no Thumbs Up
Post #31671 13th Oct 2010 10:24pm
Well there is a bit , I just spent a couple of months wondering why my TMC didn't work until I put all my plugs back in Thud 2008 MY Supercharged
Post #31687 14th Oct 2010 8:47am
