Home > Maintenance & Mods (L322) > Would you replacement the windscreen...? |
BIGMAMMA Member Since: 28 Oct 2012 Location: LEICESTERSHIRE Posts: 174 |
I had my screen replaced two years ago as I sustained a large chip, within MOT failure zone, which started to crack extensively. Auto Windscreens did it very efficiently (it was the heated but non rain sensitive type) and not had any problems with leakage or anything since - that'll be the kiss of death wont it?! |
4th Nov 2013 12:33pm |
NKSC Member Since: 09 Nov 2011 Location: Lincs Posts: 156 |
I had mine done by Auto Windscreens a few months back. The third one they fitted was a genuine LR one which is fine. See the thread below for the problems I encountered. If you do get it done insist on a genuine LR screen as there is definitely a difference - even the Pilkington one (who make the screens for LR) was wrong in my opinion.
4th Nov 2013 12:52pm |
Hi,
4th Nov 2013 12:57pm |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
I was in the same predicament a couple of months ago. I had a large chip, but also water coming in via the A pillar - fun & games
4th Nov 2013 2:04pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35267 |
the a-piller or the windscreen fitter? ... - .- -. Y. O. L. O. . |
4th Nov 2013 3:54pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Autoglass did mine and its important that they have TWO fitters on site as its a heavy screen and a two man job.
4th Nov 2013 4:41pm |
4th Nov 2013 7:59pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
I would take it and see if it can be repaired with a resin. It is usually free and a service provided by autoglass and their ilk.
4th Nov 2013 9:03pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Careful with the resin. I was told a resin repair was NOT possible with cars fitted the the heated windshield. They said the windshield heats up quickly, expands and the resin can come loose. |
5th Nov 2013 7:21am |
Nor heard that. Will ask the question, its not a failure mot wise yet as it is out of the zone and is a small chip 2-3mm but there is the start of a crack, about 5mm out of each side.
5th Nov 2013 5:11pm |
